Old 10-06-2010, 04:18 PM
Old66Tiger Old66Tiger is offline
Default Help me Plan out My EZ EFI Sytem - Regular or Multiport - Also Help with Fuel System
Hey guys...new to LatG and glad to be here.
I have a 66 GTO with a 461 aluminum headed roller motor in it. The motor is good for about 550 HP. I am currently running the RPM dual plane intake with a custom Q-Jet. Looking to make the car a bit more friendly on the street.
I was looking at the EZ EFI and the EZ for multiport. I am trying to decide which one is the better route to go for my car. The EZ EFI will keep me from having to sell my old intake and buy a $400 EFI ready intake. However, it sounds like there is some benefits to running a dry intake - just need to know what they are. Is one really better than the other for the street?
Also, I have a stock tank with a -8an pick up and return. I don't have the $1200 to spend on a Rick's tank and I don't like the looks of the external sumpd units. I was thinking about installing one of the tanksinc units that has the little tray and the pump with return contained together. Also, thought of cutting the top of my tank apart and installing internal baffles with one of the Tanks.inc pumps. My tank is used so cutting a welding is a bit precarious. I heard guys using a argon blanket or the exhaust from a running car to evacuate the oxygen from the tank. However, once the top is cut off, it will be open to the ambient air. Can i make the sump out of regular steel or should I be using galvanized steel. The fumes from galvanized are really bad for you.
Old 10-06-2010, 05:36 PM
Welcome!
Okay --
I have the EZ EFI on my Nomad - 406 - 8 stack - so running the Multiport set up. I ABSOLUTELY LOVE this system - and migrated from the Accel Gen 7 stuff.
A couple of things to think about.
Make sure your motor has good - fairly steady - vacuum.... if it's really low and jumping all over the place -- you'll have "issues".
I had my cam ground on a 114* LSA to insure a good vacuum source.... it's critical.
FOLLOW THE DIRECTIONS --- when they say run the power source all the way to the battery -- they mean it. Heavy gauge high quality wiring with quality connectors... don't short cut this!
Tach signal is best taken DIRECTLY off the tach output of an MSD box - or similar brand.
As for the question of wet or dry intake --- everything is a trade off -- but for the street -- I doubt you'd know the difference between them... so if money is an issue - just run their conversion kit for the carb intake.... it works great and you'd be plenty happy. If you want "looks" etc -- then step up and spend the money for the multiport intake and throttle body. Again - doubt you'd feel or know the difference.
There are several threads on here regarding this EFI system -- including some videos of installs by members here....
RE: Your tank
Main thing to know.... you're pumping a lot of fuel THRU this system since it's a return type EFI.... you don't want to AREATE the fuel with the return line --- and you don't want to "uncover" your pickup on hard starts and cornering or going up steep grades! A suitable well planned fuel system is critical. Most guys use their existing supply line as the return line -- and install a new (larger) fuel supply line.
#2 --- there are threads on here about welding fuel tanks. I even started one myself. The key here is WASHING the tank with SOAP -- not just water (water and gas don't mix) and using he sniff test -- if it smells like gas there is gas and or fumes remaining.... and instead of killing yourself with exhaust pipe gas ---- use DRY ICE.... it turns into CO2 as it "melts" and that is an inert gas - it forces the O2 out... Read the thread on it.
Depending on the size of your current supply line (you do NOT want to go lean on WOT!!) you can use it as a supply and add a return - some guys run the return fuel into the fill neck of their tank.... If you have questions etc post up some pics in this thread and we'll all try to help you! Don't guess -- ask lots of questions -- there's GREAT people on here...
Old 10-07-2010, 06:36 PM
Hi Greg,
I run about 11-12" of vacuum with this cam. It does not bounce much more than 1" at any time. Although, this is idling at 750 RPM and I would like to idle higher, but my carb likes to drip off the booster with more RPM than that. I think if i idled higher, the vacuum would be almost 12" Is 11" with 1" of bounce enough vacuum?
I am planning a MSD 6AL2 unit with the rev limiter. That is a nice box and should work well.
I am really stuck on the two different systems. I wish there was a clear cut advantage, but i am not finding one.
I have a thought on the tank. I will sketch something up tomorrow and post it. I hate the looks of the rear sumps. They just look odd on a pro-touring car. My idea involves cutting a 12"X12" hole in the top front portion of the tank, making a box that fits in this area with 3 trap doors. One in the back, and one on each side. The idea is that under hard acceleration, gas will force the rear door shut and trap the fuel in the sump. On a hard decel, the fule will open the trap door and fill the sump. Same goes for the side trap doors. A hard right will close the left side trap door and open the right side trap door and vise versa. The top of the box would be welded or soldered to the top of the tank and the pump and the lines would be screwed into the top of the sump box.
Since this is a used tank, i figured that it would be a good place to practice. I just need to get it cleaned out enough to cut and weld on it. Is there any solution that can help with this? i like the dry ice idea. Where can a fella get some of that?
I was going to have the pump draw out of one compartment of the box and have the return dump into another compartment. This will allow me to recess the box down about 1" below the top of the tank so i can get the lines in and out of the top of the sump box. I have -8An aeroquip line running from the rear to the front and i also have the factory 5/16" line that i could use for return. Will that work for this application?.
Thanks for the help. Bob
Old 10-07-2010, 08:02 PM
I put my responses in the quote in red... hope it helps.
Originally Posted by Old66Tiger View Post
Hi Greg,
I run about 11-12" of vacuum with this cam. It does not bounce much more than 1" at any time. Although, this is idling at 750 RPM and I would like to idle higher, but my carb likes to drip off the booster with more RPM than that. I think if i idled higher, the vacuum would be almost 12" Is 11" with 1" of bounce enough vacuum? That's plenty of vacuum and is pretty darn steady!
I am planning a MSD 6AL2 unit with the rev limiter. That is a nice box and should work well. Perfect.
I am really stuck on the two different systems. I wish there was a clear cut advantage, but i am not finding one. Can't help ya there...
I have a thought on the tank. I will sketch something up tomorrow and post it. I hate the looks of the rear sumps. They just look odd on a pro-touring car. My idea involves cutting a 12"X12" hole in the top front portion of the tank, making a box that fits in this area with 3 trap doors. One in the back, and one on each side. The idea is that under hard acceleration, gas will force the rear door shut and trap the fuel in the sump. On a hard decel, the fule will open the trap door and fill the sump. Same goes for the side trap doors. A hard right will close the left side trap door and open the right side trap door and vise versa. The top of the box would be welded or soldered to the top of the tank and the pump and the lines would be screwed into the top of the sump box. Complicated.. I don't like moving parts...
Since this is a used tank, i figured that it would be a good place to practice. I just need to get it cleaned out enough to cut and weld on it. Is there any solution that can help with this? i like the dry ice idea. Where can a fella get some of that? Soapy water - I used SIMPLE GREEN - twice - rinsed really well - let it air dry for a couple days... DRY ICE is available anywhere they sell fish - try your local grocery store.
I was going to have the pump draw out of one compartment of the box and have the return dump into another compartment. This will allow me to recess the box down about 1" below the top of the tank so i can get the lines in and out of the top of the sump box. I have -8An aeroquip line running from the rear to the front and i also have the factory 5/16" line that i could use for return. Will that work for this application?. Sounds pretty good but a 3/8 return might be better. There are "rules" on line size - I just don't know them.
Old 10-08-2010, 07:45 PM
I was thinking about modifying my tank but now i am thinking of just getting a pre-made tank. I have narrowed in on either Rock Valley or Ricks. This is no canyon carver but a serious street car. I want a tank that is beautiful and performs like it should. I don't want issues with the pump running out of fuel due to sloshing, etc.
From the pictures that i see on Rick's site, the tanks are a brushed finish and look great. I have seen some pictures on the board for the RV tanks and they are not as polished. OR am I wrong? so hard to tell from pictures on the boards.
Old 10-11-2010, 08:10 PM
David Pozzi's Avatar
Take a look at the Ricks Vaporworx tank, it uses a late model fuel bucket with pump inside and is proven to work.
http://www.PozziRacing.com
