Old 10-08-2010, 12:15 PM
Todd ---
I had to chuckle to myself -- thinking -- no wonder I got rid of all my 69 Camaros -- the driveline tunnel is just too damn small!
Old 10-08-2010, 12:24 PM
67ragtp 67ragtp is offline
Thankyou Greg and Todd- Appreciate your time explaining it. I think its clear now. My drive shaft should be delivered next week so I will mock it all up and start measuring angles to get it right. If I have to cut the tunnel then it will get cut.
Thanks again Rich
Old 10-08-2010, 12:36 PM
There ya go Rich.... And Todd is totally correct and I completely understand the issue with the low stance trying to be achieved etc.
In most cases -- you'd have a down tailshaft angle and a nearly equal UP pinion angle - but if YOU did that your driveshaft would be going UP towards the rear and interfere with the tunnel.
I was attempting to get you to understand that the angles are more than just one goes this way and the other goes that way... so that when you're setting this up you have a firm understanding of the possible issues of vibration and u-Joint problems you'd be creating. I also try to write so that others can read the posts and "get it" as well.
The more we all do this stuff -- the more respect I have for the engineers that design factory cars -- ala the Vette and Camaro etc.... they're getting huge horsepower in these cars and they have fantastic road manors and they're built in mass... Then we come along and try to do all this engineering in our garages.
Old 10-13-2010, 03:38 PM
Think I need a bit more help. Ive got the driveshaft in. It measures .7 degrees going down towards the rear pinion.
The trans is at 4 degrees down
The rear is at 2 degrees down
Front working angle = 3.3
The rear angle is where Im confused do I add or subtract them : 2 +.7= 2.7 deg or 2 - .7 = 1.3 deg
It doesn't seem to bad if the rear angles are added only 1/2 a degree apart. If it goes the other way theres 2 degrees between the two.
Thought?
Thanks Rich
Old 10-13-2010, 05:10 PM
Rich, you subtract the angles if they are on the same plane and add them it they are not.
Your scenario:
Add:Your rear pinion is pointing down from level 2 degrees and your drivshaft is sloping up towards the front of the car .7 degrees. They are on different planes so you add them to get - 2.7.
Subtract: Your drivline is pointing down from level 4 degrees and your driveshaft is sloping down towards the rear of the car on the same plane .7 degrees. Your working angle is -3.3.
Now you see why I mentioned raising the tail shaft of the trans. The RIGHT way to do it is to have equal and opposite numbers. You have two negative numbers but that's all you can achieve without slicing and dicing the tunnel. I'd at the very least take it out for a high speed run before you put in the carpet and dynamat if you decide to run it this way. I'd cut the tunnel.
Old 10-13-2010, 06:37 PM
Thanks again Todd, Im convinced now. My trans is always going to be down even if its 1 degree, the only way to get them close to equal and opposite will be to bring the rear pinion up slightly over level. Even cutting the tunnel the bell is close to the floor/firewall. Thanks again - Rich
Old 10-13-2010, 08:03 PM
I'm a little confused by your post. If you are able to raise the tail shaft of your transmission to achieve a driveline angle of 2-3 degrees, you will then be able to put your pinion on the same plane as the driveline and have equal and opposite numbers. This crap can be very confusing at first.
Old 10-14-2010, 04:22 AM
Sorry for the confusion, the transmission is currently extremely close to touching the tunnel, I can not raise it any further. The tail is at 4 degrees down. My last post was simply a speculation of where these angles will end up if I cut the tunnel and raise it.
Rich
Old 10-14-2010, 06:58 AM
Rich -- Todd is right - cut and raise the tunnel while you have the chance.
Old 10-14-2010, 07:28 AM
Gotcha Rich..
