Old 10-14-2010, 09:25 PM
Here is the cageI did with por 15
before
And after
I did all the steps, and yes it took a long time.
I did not care for it so much on larger flat surfaces. I had a hard time getting it as smooth as I would have liked without spraying. I only used it on large flat areas where it wouldn't be seen or would be covered. It did self level very nicely on the bars. Maybe with some more practice the flat areas would have looked better.
Old 10-29-2010, 03:17 PM
69x22's Avatar
69x22 69x22 is offline
Default Por-15
I would wear a filtered face mask, also you get that stuff on you it will be there for a while. It is good stuff though.
Old 11-03-2010, 02:13 PM
1969x11's Avatar
1969x11 1969x11 is offline
If POR-15 is junk -- I sure wish someone would come get that junk off my concrete floor 'cause I can't!!
I got a good laugh out of this!! I cant get this junk off my floor either.
Old 11-03-2010, 08:28 PM
camsdad's Avatar
camsdad camsdad is offline
Me Too! Eight years into my project and still stuck to the floor too!
Kurt
1969RS Holly Molly! Its Done!
Dart SHP 400, Holly Terminator X Stealth EFI , 200R4 Trans, 3:42 Posi 12 Bolt axle, Cold ones in the fridge Dam, all gone Be right back!
Yeah Baby!
Old 11-04-2010, 07:01 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Originally Posted by jcal87 View Post
I just ordered the floor pan kit. I'am wondering how effective this stuff is? I have some pin hole rust spots on the driver and passenger toe board that i want to paint over with this stuff. Also is there any prep work that needs to be done such as grinding or sanding?
is that the kit with the mesh & putty? I'm curious too see how that works out.
POR15 does not like new smooth surfaces, so for floor pans and such make sure you etch clean metal real well with their etcher.
that stuff gets harder as it cures. I did my LCAs with it, I scratched one of them a week after I did them. months later they are far more scratch resistant.
Scott from NJ
Old 04-08-2011, 09:57 PM
64impala's Avatar
64impala 64impala is offline
KBS Rust Seal!!!! Its a 3 step process...aqua blast, rust blast, then rust seal...And for undercoating the BEST product is Monstaliner! Look up these product because they worked wonders on my 64 impala restoration. My 2 cents
Old 12-21-2014, 03:45 PM
snappytravis's Avatar
Default Rust Bullet vs Por15?
Just curious what the feedback is on these two products. They seem very similar. I also looked at the eastwood ceramic chassis paint
I plan to paint the chassis a semi gloss black and then us a bedliner kit for the floor pans on the bottom of the car. I see on this post a guy uses Monstaliner with a roller.
Thanks Travis
Old 12-21-2014, 05:20 PM
I've used POR15 on many things - rear end housing - suspension A arms - Chassis.... The key to this (as with any coating) is cleaning and etching for a good grip - the paint is only as good as it's surface adhesion.
POR15 --- you can hit this stuff with a hammer and dent the metal without chipping it! LOL -- Get it on your cement floor or yourself - you'll find out how tough it is. Open the can -- use it -- try to reseal and get that can open again - NOT! Buy small cans -- use them - toss 'em. Ditto anything used to apply the stuff short of your spray gun - that would have to be cleaned.
#1 NOTE --- this stuff takes a LONG time to dry -- thus -- if you'd like your parts to look perfect - you'd better be in a dust free environment. It will have dust in it. This is not show quality paint -- it's made to paint over rust (thus the name P O R).
#2 NOTE --- Don't try to use a sponge type brush.
#3 NOTE --- Don't try to brush the stuff out... it will FLOW out plenty smooth. Remember that long drying duration? That's what has the paint flowing out flat.
Old 12-21-2014, 08:31 PM
Thanks GW,, That is basically what I am wanting to use it on, chassis and differential housing. It is clean bare steel. Just want something durable and easy to touch up.
Old 12-21-2014, 09:01 PM
Good uses for it -- where it's dark and mostly out of sight - unless you're name is Mario (Doom) and you're trying to build a Ridler car.
I use the prep spray they sell --- Marine Prep I think it's called -- nasty stuff - spray on rinse off... then paint when it's all dry.
