Old 10-22-2010, 02:11 PM
LILBuzzy's Avatar
LILBuzzy LILBuzzy is offline
A Watts link, panhard, etc. should really only be used if all the links run straight.[/QUOTE]
thanks for the input. i wanted to keep the factory three link without having to do anymore frame mods. except maybe put the panhard or watts back on.
Old 10-22-2010, 02:14 PM
LILBuzzy's Avatar
Originally Posted by 5280/4 View Post
Lateral-dynaimcs 3 link uses triangulated lower links with a center upper link and a watts. With triangulated lower links part of the roll center is defined by the intersection point.
i guess that is the type set up i am trying to do. just playing around with some ideas now. thanks for the input.
Old 10-22-2010, 03:27 PM
exwestracer's Avatar
exwestracer exwestracer is offline
The lower links on the Lateral Dynamics setup aren't really "triangulated" either. The angle in the lower links comes from the forward pivots being relocated slightly inboard for tire clearance.
For all intents and purposes, we could consider those "straight" links.
Just posting this to try and help any confusion with the Satchell design.
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 10-22-2010, 08:53 PM
LILBuzzy's Avatar
Thanks again. I guess triangulated is too far fetched of a description. They are merely angled. I don't mind stealing knowledge though.....so keep on educating me.
Old 10-23-2010, 07:11 AM
Default Link suspension 101...?
I just grabbed this picture off the net, but it illustrates the main concern with a true triangulated link suspension.
http://www.akfabshop.com/alaskaoffro...k_Topangle.jpg
In this case, the upper links are the lateral locating device. There is no Panhard bar or Watts, etc. It is the angle between the links that holds the rear axle in place. The wider the angle (red lines), the better the job the links do of controlling side motion. That's why most factory setups are close to 90deg included angle. BUT, this leads to short upper link length, lots of pinion angle change, and a lot of bushing bind in roll. Narrowing up the angle (green lines) frees up the suspension in roll, but does a poor job of keeping the housing firmly in place under side load. In a "lateral-g" car this is far more important than free movement, as travel and roll angles are purposely limited (low ride height and flat cornering). 60deg is the typical minimum included angle for a street vehicle, closer to 90deg would be better.
The intersection of the links does define the roll center in height and location relative to the axle housing. That is one reason I personally am not a big fan of the "reversed" triangulated links (narrow at the front).
Now, back to the lower links... As I mentioned earlier, ideally we would like to keep the lower links as straight (to chassis centerline) and level to the ground as possible. The bigger the tires and engine (torque output), the more important this becomes, regardless of what we are doing with the upper links. The more the lower links are triangulated, the more the "push" from the rear tires/axle is going to try to move the housing around. It may not actually move, but the loads on the link pivots, Panhard bar, etc. go way up; especially when we have a difference in rear tire loading (like accelerating out of a corner?). Combine that with the roll center being low and located way ahead of the axle centerline, and you have the potential for a lot of "monkey motion" from the rear tires during hard use.
Now for my disclaimer...people do all of these "bad" things with suspensions all the time, and enjoy the hell out their cars that way. I believe that designing these problems out from the start gives the driver a better seat of the pants feel and makes the car more consistent, easier to tune, etc. Bottom line is, build it safe, drive it, and have fun...
Old 10-23-2010, 03:58 PM
LILBuzzy's Avatar
that's deep. and i thought explaining photosynthesis and respiration to my freshmen was a job!
Old 10-26-2010, 04:23 PM
Mean 69 Mean 69 is offline
The lower links on the LD setup are angled inboard (plan view) for a very specific reason, and it's not tire clearance. In doing so, they form a lateral resistance that in conjunction with the bellcrank position (which in this case defines the rear roll center height), defines the rear roll axis. Trust me, I know the guy who researched and designed this setup (he's kind of a difficult person to deal with). With the angle of the lowers in plan view, and more importantly the fact that there is only one upper link (relative to Terry Satchell's design illustrated), one additional constraint is needed to appropriately locate the rear laterally (Watts, in this example). Actually, even WITH the modest lower angle, the lowers would be sufficient enough to locate the rear laterally IN THE CASE of a Satchell. However, it would be very impractical in that the entire system would need to be made so strong as to eliminate any bending and flexing, or the system wouldn't work, which is why the typical angles on those types of setups approach or exceed 45 degrees (nature likes that number...).
The LD setup was designed to have a bit of liberty to adjust the rear roll center height to accomodate roll resistance and jacking force reduction, as a primary adjustment. One could also use the system to define the rear roll axis as a primary setup and let other parameters "float," but typically this is not the case. The entire adjustment envelope of that system is such that even at the extremes, nothing gets too far out as to create a diabolically handling car, at least at the rear.
That is certainly one design approach, but there is more than one way to skin a really fast cat. The LD approach considered this, and designed differently for very sound engineering reasons. In terms of force application being an issue with angled lower links, again, if the structure, links, rear housing and all other mechanicals are sufficiently rigid, this is not an issue. Certainly within the traction potential of a 345 wide R Racing compound road race tire in this example, a "modest" contemporary "Pro Touring" inspired engine (750 HP?), and portly curb weight (3400-3600 lbs, more?), there is not an issue with this approach. Honest. And I'm not trying to get into a wee-wee contest at all, there was a LOT of thought put into that system and virtually no design element was done without regard for consequence. You need to pick your battles, as you can't have it all in one package.
Back to your regularly scheduled program.
Mark
Old 10-26-2010, 08:33 PM
Mark
Apologies for my lack of insight as to the LD design paramters. I have seen a number of these setups done in exactly that fashion for tire clearance. My comments regarding keeping the links straight and level are general "can't go wrong" guidelines for those who are unfamiliar with the intricate details of link type suspensions.
Old 10-29-2010, 11:46 AM
SuperB70's Avatar
SuperB70 SuperB70 is offline
About wishbone, I think some explaing is in order.
I'm thinking of dragstyle,not offroad full welded structure, here we have a simple capitol A with one extra tube coming straight down from to top of the letter and there is another free movement tube going out inside this tube and they make a kind of telescope structure. There is two connections at bottom ends of letter A and one on the end of inner tube. It will go shorter or/and longer with suspension movement. So it will never ever prevent it and nothing like ladders cos Wb not full weldet structure.
Exwestracer is right track with me here. Wb is problem free desing. It's more free than wattlink.
I calculatet that it can be fab it around rearaxle 8 diffrent position and ways and all they can be same as cars centerline (or what its call'd)
If you use Wb it will take all side to side forces of your suspension link tubes.
Again, I not saying that you all are wrong, just that there is easyer way to do it right.
This was the way I did it in my Swinger six years ago. I did welded some extra 1/4" plates after I bend it speeding way to fast in Estonias back roads.
