Old 11-19-2010, 07:00 AM
dhutton dhutton is offline
I spent the $25 to have Pat G (you can google him) design a custom cam with the EPS lobes for me. I'm combining that with AFR heads with a goal of good drivability with decent low and midrange torque. In my case I am not focused on peak dyno horsepower since the car will be largely street driven.
Don
Old 11-19-2010, 09:45 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by Nemesis RR View Post
all those cams are to big and power will not start until after 3000 rpm. I would look at texas speed for suggestions. Just an opinion for more overall power.
I recommend Texas Speed as well. I bought a 408 iron 6.0 short block from them. Told them the heads I were going to use (L92 of course) and they told me what Comp Cam to use and the appropriate head gaskets for my desired application. Great guys to work with.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-08-2011, 12:23 PM
SoCal_63 SS SoCal_63 SS is offline
Default Gracias
Hey guys!
For some reason my notification turned off (or maybe I didn't set it up??!??? )
Thanks for the good information. It would be great to maybe put together a list of LS2 specs from everyone. Then over time a User could sort of pick what they were looking for as far as end result and then copy the build...
Here's mine:
Intended Use: Street/track, Pro-Touring build
Engine: 2007 LS2 (TBSS motor)
Crank: Stock
Oilpan: F-Body (Pace Perf: PAC-8771)
Heads: L92 (Scoggin Dickey: SD8801-1)
Intake: TBD - LS6 or F.A.S.T or Holley LS 92mm High Ram
Compression: ~ Stock 10.6/1
Cam Specs: TBD
Idle Quality/RPM: Lumpy!!
Fuel System: TBD : Aeromotive Stealth A1000 cell or similar build
Max HP: TBD : aiming for 500 range
Max Tq: TBD : aiming for 500 range
Old 07-08-2011, 04:04 PM
rocketrod rocketrod is offline
I just called Texas Speed this week and would suggest you do the same.
I am planning on installing the same setup LS2/4L70E out of a Trailblazer. They recommended a 228R with 114 LSA with stock heads and and LS2 manifold to keep the powerband in the lower rpm range versus the upper if you go with the L92/Ls3 heads. With good headers, ls2 car intake, good tune and the recommended cam you should get you over 500hp. This cam is mild so a bigger would yield better results.
Here is a link to the cam http://www.texas-speed.com/p-1158-te...pring-kit.aspx
Rod
1969 Camaro - LS2/4L70E
Old 07-22-2011, 09:23 PM
Jgpclone's Avatar
Jgpclone Jgpclone is offline
Originally Posted by SoCal_63 SS View Post
Hey guys!
Here's mine:
Crank: Stock
Cam Specs: TBD
A good cam for that motor would b I'n the range of 224/228 650 114 lobe sep that if ur going to use a 4l60.as for heads check out west coast cylinder heads I'n reseda ca if I was u I would port and polish the heads of the ls2 but that's just my opinion
Hi my names is danny and im a "hp junky"
2006 tbss stock dd
1969 camaro project
2004 scsb silverado joe gibbs clone
