Old 01-10-2006, 05:29 PM
907rs's Avatar
907rs 907rs is offline
Try these guys for the Honda parts: http://www.haprecycling.com/
The owner is a member here, and is an excellent guy to do business with.
Bill
Old 01-15-2006, 07:17 PM
4FTTY4 4FTTY4 is offline
Did anyone ever come up with a schematic or wiring diagram for a chevy? I had one from a miata and it wasn't very helpful...
Old 01-15-2006, 07:52 PM
Kendall Burleson Kendall Burleson is offline
we are building a new botton to mount on the dash but we are trying incorprate a no & off switch if you can wait about six week we should have it ready for sale with instruction to hook it up.
Old 01-15-2006, 10:02 PM
let us know when your kit comes out, I know I'll probably take you up on it. I think my button may have gotton fried by my wiring attempts...
Old 01-16-2006, 05:35 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
I was thinking of a different way to do this so that it would work more like a 2005 Vette where no metal key is required at all.
My thinking is to work with the existing switch and wiring for reliability and ease of service.
Since my 69 Vette does not have a dash mount switch (68 would), I thought of the following.
Installing a Linear actuator (www.uslinear.com) on the steering column set up to push the ignition switch forward to the run position when you activate it with the keyless entry remote (option 1). Once this is activated the car is ready to start. I would run the START ENGINE button in the steering column mounted flush in the stock metal key ignition switch lock housing. It will still be wired through the alarm and neutral saftey clutch switch. In other words you would have to be in the car holding the clutch to start.
To turn the car off I would activate the Option 1 button on the keyless fob. This would trip the relay and cause the linear actuator to move back releasing the ignition switch on the column.
Because it would be tied to the alarm, simply breaking the actuator out and manual moving the column switch forward would not allow the fuel pump and ECM to go active so the car might spin over, but not start.
Still hammering this out in my head, but I think it will work.
Old 01-16-2006, 12:37 PM
Mikael A Mikael A is offline
Originally Posted by Damn True
Id like to find some way to not have my keys wagging back and forth across my dash ('68 Camaro). I dig the idea of an ignition switch in a cubby in the console and a push to start button (ala Honda S2000 or Lexus) in place of the ignition switch on the dash.
Anyone done anything like this?
Have suggestions?
Have a schematic?
Muchos Mahalos!
try www.ignitedperformance.com and go to product instructions
Mike
Old 01-20-2006, 01:37 PM
Steve68 Steve68 is offline
Hey Guys, I got a schemetic from ls1camaro.net, in the section fourm
it shows a relay and diagram for the S2000 switch and a cheap place to find the pigtail,
on the P/T board awhile ago the was athread about a aftermarket push button switch, I liked it better than the Honda part,
Old 01-20-2006, 03:32 PM
Damn True's Avatar
Damn True Damn True is offline
Can ya link that?
Old 01-20-2006, 05:56 PM
http://www.ls1camaro.net/sections.ph...ticle&artid=12
Old 11-22-2007, 06:05 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
can some body explain how this works? do I still need a key?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
