Old 12-02-2010, 03:36 PM
MC71Nova MC71Nova is offline
Default Nova Disc brake conversion - easiest bolt on kit
Hi All,
I'm a decent shade tree mechanic... removed and replaced motors, do my own maintenance, switched out a master cylinder before, etc. But I'm not an expert by any means. I'm looking for the least complicated, most complete 4 wheel disc kit for my '71 nova on the market today. Would love to get a larger than stock front disc if possible (but don't need it) and I have power drums now so want a power setup. Every kit I see seems to lack the hard brake lines from the proportioning valve to the frame. Is there a kit that uses the stock lines? Do they need to be replaced? other than that is it a pretty straightforward job? I'm using the stock a-arms but would need a kit with the proper spindles obviously. Do these kits move the wheel/tire out or in from stock drums? Any expertise would be appreciated! I'm looking to keep the entire budget under $1K if possible, start to finish, doing the work myself. Looking for new parts, not used or takeoff from another model. Thanks!!
Old 12-02-2010, 06:51 PM
NvrDun71 NvrDun71 is offline
Give Tobin at Kore3 a call. Your budget may be tough to hit, but he should be able to get you squared away.
71' Nova - LY6, T56
Old 12-02-2010, 08:18 PM
We have a factory stock replacemnt (4) wheel disc kit that DOES include all the pre bent hard lines and all. Absolute no brainer kit.
We also have our Exlusive Prodigy Custom Total Car G Machine Brake Packages featuring larger then stock Baer or Wilwood brakes that include everything including "You Bend It Line Kit" and tools to do it with. It is pretty much a no brainer also.
All depends on budget and needs, The phone call is free.
Frank Serafine
Old 12-02-2010, 09:14 PM
scherp69's Avatar
scherp69 scherp69 is offline
Frank, can you post details of the 'you bend it' line kit. By spring, I'd be interested in a stainless steel kit.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 12-02-2010, 09:32 PM
Excellent! Thanks, so much for the ideas! I have looked at the Kore 3 stuff but it looks pricey. But I'll give the other option a try and call. Thanks.
Old 12-03-2010, 09:03 AM
OnEdge OnEdge is offline
You can find a used set of c5/c6 brakes for roughly $400 or so. Then you can either buy the brackets or buy them from Kore3. I just bought a compete set of C6 rotors, calipers and flexible lines for $400 and they only had 4k on the them. They still look brand new. Hope this helps.
Ryan
72 Nova "in progress"
