Old 12-21-2010, 12:36 PM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Just so I understand this correctly, QA1's pretty much have a (safe) ride height adjustability window of 1.5"? That being said, does it come out of the box with a lower ride height than a stock spring and you can drop it 1.5" from there? Or does it start out with a similar height as stock spring?
Oh yeah, and do QA1's work with stock arms? Thanks.
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 12-21-2010, 05:57 PM
They come out of the box "how you ordered them". There is a good explanation of all of this on their (QA1) website - or consult an expert.
Coil overs - regardless of brand - have an extended length - and a collapsed length --- and an "as installed ride height" length. It's the installed ride height length that will wreck havoc on you if you think you can install a set and then just crank the car up and down with the spring adjuster nut.
If you want the car to set low -- then you need to set it at the ride height you want -- then measure the mount points -- and order a coil over accordingly. Of course this is oversimplification - because there is also bump steer issues if you get your A arms and rack out of whack... and there are clearance issues for turning radius and a bunch of other stuff that comes into play.
One of the reasons people do air bags -- is because they want to raise the car for driving - lower it for slow speed cruising - or slam it in the weeds for a show etc. They make that super simple. Coil overs however - are really not for doing that.
If you want to just lower your car - and I'm assuming it's the mustang in your avatar.... then you can do a set of lowering springs and the accompanying shocks and or struts. My daughter has a 2006 Mustang and it's been pretty aggressively lowered.... so low using the Eibach lowering springs -- that it ruined the ride. I had to have her take it to Fesler in Scottsdale (she's down there in college) and have him "fix it". Now it's low but rides 10X's better. Not sure what he did. I just paid the bill.
Old 12-21-2010, 06:39 PM
realcoray realcoray is offline
I think it's 1.5 drop from stock but again this is just what I recall hearing, I know it's a narrower range than they list.
The QA1 coilover conversion will work with stock arms although I would probably suggest at least looking closely at your arms. The conversion changes what is holding weight from the lower spring pocket to the T bar mount area. A 40 year old stock arm may not be the most ideal thing to rely on.
Speedtech and DSE both have true coilover conversions that allow you to change your lower & upper mount to an eye mount, and you can also buy whatever coilover you want.
Old 12-21-2010, 07:14 PM
I should have gone back to check the original post... I see you're questions are about your '69 Camaro -- not the Mustang in the avatar.
Either way - What I have said above is the same.... you have to "set" the stance you want FIRST - then order shocks and or coil overs / springs to fit that rather than try to adjust a too long set to make it sit lower.
There are so many '69 Camaro builds on here - it should be fairly easy to find a thread with a build you like -- and ask the builder / owner how they got there.
Although - there are plenty of people that have ordered them all wrong and learned the hard way that there are a few things to consider BEFORE you order... I know I have at least two complete sets (4 ea) on the shelf from a couple builds that either changed along the way - or didn't sit quite right!
Spring rate - and LENGTH is just as important as the length of the shock they're going on or around.... Most of the shops and manufacturers that sell this stuff should be more than happy to help guide you thru the process. I seriously doubt you're doing anything "new" regarding what look you're trying achieve.
Old 12-22-2010, 01:29 AM
mrr1999's Avatar
Thanks Greg-
Yes, it's for my Camaro. I'm only looking to drop it roughly 2 inches but I wanted to get it right the first time I tried it, so thanks. I'll establish the ride height I need before ordering. My concern now is whether the stock arms will be ok with the coil overs. If it isn't a good idea to use the stock arms, I may have to reconsider the DSE or Hotchkis lowering springs so I don't break the bank (for now).
70 Chevelle SS396
69 Mach I
Old 12-22-2010, 06:49 AM
Mike --
Try SpeedTech also.... they have options for Arms / Spindles / coil overs etc.
I don't know about stock arms and coil overs... since that just isn't an option I would have ever tried. A simple upgrade is to use aftermarket A arms - and get much more benefit than just the strength!
Old 12-22-2010, 04:56 PM
SLO_Z28 SLO_Z28 is offline
Greg is the first person ive ever heard make sense when talking about coil overs on the internet.
The short story on coil overs is if you have to ask about them, you don't need them. They are not intended for ride height adjustability, although that's what they get used for most of the time, its not the reason or the purpose of said adjustment. They are solely to cut weight and for corner weight adjustment. There are other benefits too but that discussion can get rather technical rather quick. Most coil overs wont work very long with stock lower control arms, but a little metal and a welder can fix that.
Get a set of Hotchkis springs and matching shocks, dont cut them and 99% chance you'll love the results. make sure and toss in new bushings and ball joints when you have the arms off.
Old 01-02-2011, 06:25 PM
JRouche JRouche is offline
So true!! Many folks see adjustable and think ride height. Ride height is based on the control arms, NOT the springs, if you want performance.
Same think with air springs. Folks see products like air ride springs (I have shockwaves, think progressive coilover) and think there is some adjustment for ride height.
Not so. There is no adjustable ride height suspension out there that doesnt compromise performance.
When I market my variable upper control arm mount to the public then you will see a truly variable ride height system. Yes, it will be fast and completely independent unlike fixed upper arm mounts. Caster and camber will be computer controlled and bump steer will be a thing of the past.
Want a look into the future think electromagnetic fluid. JR
Old 01-03-2011, 08:43 AM
Bryce Bryce is offline
One other advantage of coilovers:
If you have a determined your ride height and measured the shocks at that height and order them and decided on a spring rate and the car sits too high or too low, you can dial in the coilover spring nut adjuster to get the car back to the predetermined height.
If this was a conventional spring you would have to cut the spring or shim it or order new ones.
Old 01-03-2011, 08:53 AM
Well..... yes...... and no.
If the spring rate is wrong for the car... you can thread the nut up and put yourself into a coil bind situation.
Really, the best part of coil overs is IF you ordered the wrong springs - or the car changes and you need different springs is, they're relatively inexpensive - and super easy to replace! Which is the CORRECT way to solve the issue(s).
