Old 01-28-2006, 11:29 AM
rocketrod rocketrod is offline
Originally Posted by JamesJ
I think that what he is saying is that your description is lacking and once anything is built or used, its only worth so much.
I agree. More details would be a plus such as compression ration , cam specs, machine work performed, etc.
Old 01-30-2006, 08:05 AM
jay web jay web is offline
Default Engine Specs
ok - here you go
ZZ4 block - line honed, bored & honed w/plates, decked, balanced
ARP main bolts
clevite rod bearings
acl cam bearings
brass freeze plugs
ARP oil pump rod
ZZ4 oil pan / windage tray
3.750 COLA crank
cloyes double roller timing set
6" crower rods
SRP pistons
speed pro rings
COMP roller cam & lifter set = (p/n 08-000-8)
gross lift = .520/.540
DURATION @.006 TAPPET lift 288/293
installed @106 intake centerline = duration @.050 236/242
fel-pro head gaskets
1.6 rockers
arp head bolts
modified 750 holley
air gap intake
MSD dist
pro-topline alum heads (123 4000 20a 4350 0502)
compression ratio is @ 9.5:1 / runs on pump gas
let me know if there are any questions, please
Old 02-06-2006, 12:26 PM
bump ttt
Old 02-14-2006, 10:02 AM
best offer?
