Old 01-09-2011, 06:31 AM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
Dude! There is only one thing to say here - and it's not meant to hurt your feelings -- but FLUX CORE is for farmers repairing tractors in a field where carting gas out there is too much of a chore. Stop using FLUX CORE to do car repair welding unless you're just welding up a jalopy frame.
I'm aware and I will stop once able. No worries.
Old 01-09-2011, 08:55 AM
redfire69's Avatar
redfire69 redfire69 is offline
I'm no expert, but flux core can weld fine for beginners. Not all of us can buy all the best tools at one time. You'll find you can weld thinner materials easier when you switch to the bottle.
Ron
69 Camaro Redfire
Old 01-09-2011, 11:00 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Hopefully, not too much of a hi- jack....if so, please disregard.
I have also done the mig to tack, then tig to fill in with good results. As Greg said the ability to more easily grind the tig filler and hammer and dolly it helps a ton. I'm very far from great at this BTW, but I try.
Has anyone used "ez grind" mig wire before? I haven't, but am curious about it. It supposedly has properties closer to the tig weld for grinding and hammer and dolly work.
Oh and fit up, fit up, fit up is huge........i struggle sometimes to pitch a patch in the trash, but if it isn't right......do it and make one that fits right. You will be better off in the end.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 01-09-2011, 11:33 AM
Sieg's Avatar
Sieg Sieg is offline
How does Lincoln's Superarc L-56 wire perform in the OP's situation?
Old 01-09-2011, 12:21 PM
Some folks aren't aware of the limits of flux core -- so I'm glad you are. I know it's an extra expense etc to go gas --- but is truly worth it. Flux core is just kind of a crude way to try to do thin materials that hot rodders have to work on.
Old 01-09-2011, 06:21 PM
Musclerodz's Avatar
Bottle lease and gas is cheap. I own my bottles, but that also limits who will fill them for me.
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-09-2011, 06:36 PM
MoparCar MoparCar is offline
LOL but I so agree. Get the gas and get to welding some nice stuff!!!
Wes
Old 01-09-2011, 08:09 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
I am using the ESAB ez grind. It does seem a little easier to work with than standard mig wire. I found out about it from a fabricator at a rod shop.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 01-10-2011, 04:21 PM
DOOM's Avatar
DOOM DOOM is offline
Talked to Jason (WAR) yesterday and he set me straight. I was making MANY mistakes. But he has me dialed in now, so it should go a little smoother . Will see, if not he's getting a plane ticket real soon!!!
Mario
USCOLLISION
Old 01-10-2011, 04:27 PM
Good to hear buddy!
It is one of those "ah ha" moments when all finally goes as it should.... and then you're off and running! Today a patch panel - tomorrow an entire tube chassis!
