Old 03-12-2011, 11:43 PM
John510's Avatar
John510 John510 is offline
anyone have a pic of pipes that turned blue?
[SIGPIC][/SIGPIC]
Old 03-13-2011, 10:38 AM
Rhino Rhino is offline
Maybe I'm a little odd in this regard, but I love the blue and golden colors stainless headers get over time.
Old 03-13-2011, 11:07 AM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
There's a product in the Harley world that you put on the inside of the tubes and is supposed to prevent the blueing but I don't first hand know how well it works. There are two, from the company that makes Kreem Gas Tank liner, called Dyno Kote and Blue Shield.
Another 'ol school trick is to coat the inside of the header pipe with grease or a film of oil before first starting. It will smoke a lot but not hurt anything and as the grease or oil burns off a carbon layer forms on the inside of the tube insulating enough to prevent the blueing.
I haven't tried either of these personally, they're just things I've heard about that might work.
Erik
69 Camaro
Old 03-16-2011, 09:14 PM
Hully's Avatar
Hully Hully is offline
I have a set of Stainless Works Pollished headers on my 68 Camaro 502 w/3" ss pipes they are a very well built product.
Don McMillon
1967 SS 396 Indy Pace Car Camaro
1968 Camaro SS Conv. FI 502
1968 Camaro Pro-Touring Project HULLY
1998 Mallett 427 Corvette
2007 Z06 Corvette
1967 Corvette 427/435 Roadster
Old 03-17-2011, 09:28 AM
Blake Foster's Avatar
one thing you MUST DO!!! is wipe the tubes with rubbing alcohol prior to starting the motor to remove any finger prints, if you dont they will burn into the pipe and you will never get them out.
Stainless works sells a product
http://www.stainlessworks.net/cart/p...oducts_id=1305
Blake Foster
www.speedtechperformance.com
Old 03-20-2011, 04:26 PM
John510's Avatar
Do they hang down lower than the oilpan?
[SIGPIC][/SIGPIC]
Old 03-21-2011, 07:53 PM
scherp69's Avatar
scherp69 scherp69 is offline
Thanks for the tip Blake. I will definitely do that.
I will check that the next time I'm out in the shop. I hope to head out on Thursday as it's a day off. I'm going to say yes though. If you look at the last pic that is posted that shows how they hand down below the frame, off to the right is the oil pan and it does look like they hang a bit lower.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 03-22-2011, 12:06 AM
John510's Avatar
OK the reason I was asking is the GM muscle car oil pan is 2.75 inches taller than a normal fbody or autocraft pan. I was thinking of getting that pan since its under 150$. I was worried the pan would hit the ground but if the headers hang down 2" lower then the stock pan then everything should be fine and dandy if I get the GM muscle car pan.
[SIGPIC][/SIGPIC]
Old 03-29-2011, 08:39 PM
YES that pan will be to low it will hang down 2" lower than the headers, do the autocraft pan and be done with it
Blake Foster
Old 03-31-2011, 09:11 PM
John510's Avatar
Thanks blake I ordered the autocraft pan. When are you going to make a 1 7/8 header or 2"?
[SIGPIC][/SIGPIC]
