Old 02-02-2011, 10:05 PM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
Steve, you lose quite a bit of turning radius with the DSE sub in comparison to stock.
Why is this Todd? Does this cause any driving problems in general?
Thanks.
Ron
1969 Firebird, 4-speed Coupe
If GOD is for us, then who can be against us!
Old 02-02-2011, 10:11 PM
It has the turning radius similar to a full size truck. It's tricky on tight autocrosses.(which I hate anyway) It's due to the increased front tire width.
Old 02-02-2011, 10:26 PM
Ron Fox's Avatar
Is this with the largest size tire...275 or larger?
Ron
Old 02-03-2011, 08:36 AM
Any tire, it's the rack and steering arm.
Old 02-03-2011, 10:23 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Call up Blake at Speedtech about the Chicane coil over kit. That's another option for you. You still have to cut and weld on your subframe with either kit.
Chris
Old 02-03-2011, 10:52 AM
strtlegal's Avatar
strtlegal strtlegal is offline
I did the Speedtech Chicayne kit, just because everything was already in the car. The other nice thing is I dont have to pop my lower ball joints to make ride height adjustments.
Not sure if you have ATS spindles or not but the DSE stage 3 kit has a built in Guldstrand mod. This "might" give you a little to much negative camber.
70 Nova: LS2/Tko600. Speedtech Stuff
Chuck D
Old 02-03-2011, 01:22 PM
redfire69's Avatar
redfire69 redfire69 is offline
I think the OP has already pulled the trigger on a DSE kit: http://www.pro-touring.com/showthrea...-arm-clearance
Ron
69 Camaro Redfire
Old 02-08-2011, 05:49 AM
lutzy lutzy is offline
Yeah.. I just went with the speed kit 1 which are the upper and lower arms & sway bar.. I'm gonna buy the QA1 bolt in coil over shocks. I didn't want to start cutting and welding...
Old 02-08-2011, 05:41 PM
MrB's Avatar
MrB MrB is offline
Default Ats
Does anyone have recommendations on whether or not to spend to bucks on the ATS tall spindles added to the DSE setup?
Old 02-10-2011, 06:24 PM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
Todd, your talking about their entire aftermarket rack? Any idea if this is the same for the other subs like AM and Speedtech?
Kyle
