Old 07-15-2011, 04:30 PM
70rs's Avatar
70rs 70rs is offline
Eric, you sure a LS7 intake fits that? I didn't think so....
My input is to get on LS1tech.com and start reading. Will keep you busy for days and show you all kinds of combos/results/#s that you are looking for.
Dave,
I just realized he meant the 4 and not the 9. And depends on which heads he has. But no, the LS7 intake will not fit the LQ4 heads and I am not sure about the LQ9 heads.
However, the ls7 intake does fit the L92 heads if I remember correctly.
(see what happens when I try to think too hard? Lol!)
Eric
Old 07-15-2011, 04:32 PM
70rs's Avatar
Originally Posted by HEEP View Post
Thanks, That's good info. going to start the searching now. Anyone else have some input?
Thanks,
HEEP
Do what Dave said.
Eric
Old 07-15-2011, 04:42 PM
Flash68's Avatar
Flash68 Flash68 is offline
Originally Posted by 70rs View Post
Dave,
LQ4/LQ9 both use the same heads IIRC and the hot ticket is to use the L92 heads flowing about 330 cfm stock and $800 or so from GM. I think I read they are discontinuing them though?
And I am pretty sure you can only put an LS3/L92 intake on the LQ4/9. Or aftermarket.
Eric, I thought you knew this LS stuff. I don't have an LS either!
Here is a good article I bookmarked awhile back on the basics.
http://www.chevyhiperformance.com/te...6_engines.html
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-15-2011, 04:56 PM
70rs's Avatar
Lol.... I am driving around, in and out of the pet store, park and several other places with my 7 year old son. My head is not in "LS" mode at all. I apologize. Don't listen to me today......
Eric
Old 07-18-2011, 01:27 AM
Jgpclone's Avatar
Jgpclone Jgpclone is offline
ls7 intake dose not fit l92 heads but the l76 dose fit of the g8
http://www.ls1tech.com/forums/genera...l92-heads.html
btw lq4 is low compression motor 300 hp great for boost,lq9 high compression 345 hp better for na,but if ur going to build a stoker "370 408 416 "ether motor works
Hi my names is danny and im a "hp junky"
2006 tbss stock dd
1969 camaro project
2004 scsb silverado joe gibbs clone
Old 08-27-2012, 09:22 AM
HEEP's Avatar
HEEP HEEP is offline
Well, I'm bringing this back up becasue the guy actually came through with the LQ9. Shocked me. I was actually about to order a rebuild kit and just put new pistons in it. So, now I have the 9 in the garage, and just last week I get informed that a guy at work has an LS1 from a 1998 Camaro. So now, I ask, stay the course with the 9 or sell it for the LS1? I'm confused and ready to go forward.
HEEP
Old 08-27-2012, 10:55 AM
realcoray realcoray is offline
HEEP
I'd say you should use the LQ9. Unless you are focused on weight, the LQ9 is superior. It's larger and it's cheaper to make more power.
Old 08-27-2012, 06:36 PM
chevmech1969's Avatar
chevmech1969 chevmech1969 is offline
100% agree, but id get the ls1 use all the accesories, and oil pan, and sell the ls1 longblock, unless the lq9 already has the car stuff, or your sourceing others. then leave the ls1 alone. IMHO
Johnson's Rod'Z
A man with few vices, has damn few virtues.-Benjamin Franklin
Old 08-28-2012, 06:19 AM
HEEP's Avatar
Right now, I have the replacement muscle car pan and looking for accessories. There are so many ways of doing this. The truck accessories look horrible. the Vintage Front Runner is way out of my price range. So looking to see if the camaro setup will work.
I am leaning toward just keeping with the 9. Thanks for the inputs.
HEEP
Old 08-28-2012, 01:30 PM
rallystyle rallystyle is offline
if your going with the truck acc you can use
http://dirtydingo.com/store/product_...oducts_id=1370
that gm muscle car pan will hang way to low. holley, mast or autokraft is the way to go.
i would also stay with the lq9. the 98 ls1 is ok but not a nice. as said weight would be the only good thing about it.
1970 El camino
1969 camaro
1996 civic
