Old 04-15-2011, 06:38 PM
I'm glad Hotchkiss stepped in here and said what I was going to -- I was trying to sit the fence and not go against some of the other "advice". Our highways have too many ruts in them to make a nice driver out of a super quick steering rack and fat tired front tires.
If you don't drive it much - then the trade off might suit you... but it wouldn't go on any of my cars.
Remember -- PT -- is not "race car" -- it's a very capable STREET car... that does more things well but not all things perfectly. A race car is a race car.. a drag car is a drag car... they both suck to drive on the street. Big azz cams are fun -- right up until the time you have to drive 'em....
Old 04-16-2011, 09:33 AM
Blake Foster's Avatar
we have both available 14:1 and 12.7:1 99% of people ask for the 12.7 i have yet to hear a complaint.
either way it will be a major improvement over stock!!
Blake Foster
www.speedtechperformance.com
Old 04-20-2011, 09:15 PM
Hotchkis Hotchkis is offline
senior member
GregWeld,
Well put. We hope all this information helps enthusiasts can make an educated selection.
Old 04-20-2011, 09:48 PM
Can you get a Lee 600 series box with something other than the 12.x ratio?
John
'71 Nova (Build thread)
FFR Roadster
Old 04-21-2011, 09:28 AM
David Pozzi's Avatar
There are two lengths of pitman arms available & three different outer steering arms that all affect overall steering ratio. If you have the long 5.75" pitman & short 5.25" outer arms, your steering lock to lock is going to be close to 2 turns & very quick. If you have a small steering wheel, it can be too quick, with a 14 or 15" wheel it's fine. You can always swap to the short 5.25" pitman to slow it down. The 14 to 1 would be a very good choice if you have the long pitman & short outer arms, & it's a street driver. You MUST be sure to get a box with firm valving or it won't feel good. In addition use updated high caster alignment specs to help the car track down the road better.
David
http://www.PozziRacing.com
Old 04-21-2011, 10:21 AM
wmhjr wmhjr is offline
FWIW, I'm running a '66 GTO (A-Body) with the Lee 670 box, all the SC&C goodies, and 245 NT05s up front on 18" wheels. It's not an F-body, so obviously there will be differences. That being said, I've driven the car on highways, back roads, pretty much any kind of road surface you can think of and I would NOT change a thing. I -as well as anyone else who has driven the car walk away thorougly impressed at both the responsiveness combined with the good manners the steering displays.
Old 04-21-2011, 01:14 PM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Will the firmness change depending on what ratio you are running? Will two boxes, one 12.7 and one 14 from the same manufacturer have the same firm feel? I know responsiveness will be different - obviously.
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 04-21-2011, 03:35 PM
yes 14:1 is also avaliable , just a longer wait to assemble as some of the parts are harder to find??? according to LEE.
Blake Foster
