Old 01-23-2006, 06:53 PM
well the 283 crank in the 350 block is gonna be an "issue", im sure someplace makes the bearing spacer for small journal(283) to medium journal(350), but i dont recall seeing them. the easier way would be to use a small journal 327 block with the 283 crank, however in a street car i would highly recomend going the rollerized 350 route, after all rpms are cool, but more inches the better.
Old 01-23-2006, 07:14 PM
rocketman's Avatar
i know a guy here in town with a 302 ls1,its damn bad.
Old 01-26-2006, 08:36 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Isn't a destroked 302 just a 30 over 283? 67-68 302's were 283 cranks in 327 blocks with good rods and pistons, double hump 202/160 valves,etc. and awicked intake,Holley?
Jim
Old 01-27-2006, 12:31 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
To make a 302 from a 283 block, the 283 would need to be bored 0.125" over, to get the 4.00" bore. Only the early blocks allow this much of a bore.
Old 04-03-2012, 01:23 PM
jeepracer jeepracer is offline
[I am looking at a 302 article right in front of me and it makes 501 hp at 8000 rpm. The camshaft referenced is a Lunati RRA-675/669 w/282 deg @ .050. But the heads they used suck (old 2.02 slant plug "Turbo" heads) The engine used an Edelbrock Super Victor type intake. The crank used was a factory 302. The rods were factory "service" rods. The only bottom end change was a switch to lighter aftermarket pistons.]
@speedster-
was there anything done to the heads or were they bone stock? is there anyway i can access this article?
Old 04-03-2012, 03:59 PM
osdmike's Avatar
osdmike osdmike is offline
8500rpm Dyno pull !!!
https://www.youtube.com/watch?v=WYrqG...layer_embedded
"Super Chevy" article.
http://www.superchevy.com/technical/...ild/index.html
Sweet music!!
https://www.youtube.com/watch?v=16FRh...layer_embedded
Old 04-03-2012, 04:31 PM
what is the best head for the 302? im looking to do one for a dirt racer
