Old 02-01-2006, 07:42 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
ttt, thanks derek
Jim
Old 02-02-2006, 07:03 AM
Derek69SS's Avatar
No problem Jim
If there's one thing I'm good at, it's figuring out how to do things cheaply
Old 03-24-2006, 02:16 PM
Ummgawa's Avatar
tttop
Jim
Old 04-03-2006, 02:20 PM
projekt70chevelle projekt70chevelle is offline
Well so far my brake upgrade has cost me a whopping $470...
I'm using the 13" c5 front brakes and the ls1 12" rear discs.
Only thing left to buy is the metal to make the necassary brackets for the caliper to spindle.
Old 04-03-2006, 03:19 PM
Derek69SS's Avatar
Details??? Does this include new MC, booster, proportioning valve, etc?
Old 04-03-2006, 05:41 PM
Only thing I havent got is the prop. valve but ebay has them up for 30-40 shipped. Being a college student and working part time I've learned to be patient and have learned to branch out...
Old 05-01-2006, 07:01 PM
Ummgawa's Avatar
back to top
Jim
Old 05-01-2006, 07:52 PM
Derek69SS's Avatar
Jim, did you do the swap yet? How'd it go? (hoping I didn't miss any important details )
Old 05-16-2006, 02:06 PM
Garhett Garhett is offline
I converted from 4 wheel drums to 4 wheel disc about 6 years ago for less than $500 turn key. I went to my local dealership and looked up the spindle casting number for a '69 camaro with front discs and then looked up what cars it came on. I found a donor car in a local junk yard (I think it was a '72 Nova) and popped the whole assembly off which was a perfect bolt on for my '69. The front brakes cost me $70 bucks.
I then replaced the rear axle with an original disc brake axle out of a '78 "smokey and the bandit" trans am. The rear end only cost me $350 but the install turned out to be a little more difficult because I had to move the spring perches but after a little measuring and welding I was good to go. I'm sure there is a better rear end to use that would be a better fit, but I got a good deal on it.
Problems?
- My original e-brake cables wouldn't work and I never got replacements because they supposedly cost $300.
- I had to get a longer brake line to connect the rear axle.
- I still have the maunal master cylinder that was for the 4 wheel drums. It seems to be proportioned fine but it just doesn't move quite enough fluid for the discs. (It will lock them up on the second pump.) My research has led me to believe that a master cylinder for a '69 corvette with 4 wheel disc is what I need.
Disclaimer:
I did this swap 6 or 7 years ago. Do your research before buying to double check me.
