Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 05-28-2011, 11:23 AM
Ron in SoCal's Avatar
Originally Posted by m.adamson View Post
I checked on the pace site , and they have what im looking for, they do state that the kits are for the cts-v. It looks the same as the vette drive. I just want to make sure it will work.
Secondly, it states that the drive will not bolt to production cast iron blocks. I am running a turbo'd lq4 set up. Do you guys have any suggestions for me on what drive I should run if the Pace kit wont work ?
I'm not sure about the CTS-V drive system, nor the cast iron block issue. There was one guy who bought a CTS system from Jody (I believe) and swaped it out for the Corvette drive? I would first look for the configuration you want to run (i.e. F-Body/Corvette/CTS, high or low aleternator, high or low AC compressor) and research to ensure you will not have frame clearance issues. If you want the Corvette system from GMPP you can search for part# 19155067. Hope this helps!
Ron in SoCal
69 Camaro in progress
Old 05-28-2011, 12:55 PM
m.adamson m.adamson is offline
Im going to go with the ls2 vette (19155067) set up from pace for 800 bucks with a/c . I did some searching and apparently it will work with the cast block, just need to drill and tap a hole or 2, so no big deal. Thanks for your help guys
Old 05-28-2011, 01:09 PM
dhutton dhutton is offline
What are you going to use that factory compressor with?
Don
Old 05-28-2011, 02:07 PM
68KMARO 68KMARO is offline
Default pace performance
frank at prodigy is a site vendor and knows his stuff
rich
Old 05-28-2011, 05:27 PM
Flash68's Avatar
Flash68 Flash68 is offline
rich
was his vendor status reinstated already?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-28-2011, 06:31 PM
BanditDave BanditDave is offline
Shoot me a PM I may be able to help you out if you are still looking for a Vette Accessory drive. There is a vendor I know of who is not a sponsor who can get you the full set-up.
Thanks,
Dave
Old 05-29-2011, 04:13 PM
Don
Sorry , i dont understand you question ?
Old 05-29-2011, 04:30 PM
That compressor will not work with Vintage Air if that is the way you are going.
Don
Old 05-29-2011, 05:07 PM
ah , gotcha. This is the info i need to know haha.
Thanks for letting me know. So basically I need to be buying a kit w/o air , and talking to vintage air to get my compressor and bracket ?
Old 05-29-2011, 05:14 PM
You will probably want the Kwik Performance bracket to mount the Sanden compressor that VA uses high on the passenger's side.
Don
