Old 07-04-2011, 05:00 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
XRP has a blue and a black power steering hose that use steel reusable ends.
page 27 & 28 http://www.xrp.com/XRPCatalog.pdf. Ironworks is a dealer and hooking me up with all my plumbing stuff. It's top notch quality.
Erik
69 Camaro
Old 07-05-2011, 01:04 AM
rwhite692's Avatar
Originally Posted by DRJDVM's '69 View Post
Watching the Powerblock this AM and on Offroad 4x4 they were building a steering system with PSC components and they had black hose !!!!...
http://www.pscmotorsports.com/6-high-pressure-hose.html
Ned on the high pressure side, as already mentioned you would want 1400-1500 PSI minimum
You can get lines made to length at any hydraulic service shop and they will also have 90 or 45 degree fittings, etc to make an assembly that fits exactly how you want it.
It's not as expensive and troublesome as it sounds....Hydraulic lines get munched on a daily basis in the construction/agriculture biz and these guys know how to make up hoses.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 07-05-2011, 12:44 PM
70rs's Avatar
70rs 70rs is offline
Thats good to know.
I had no idea the PS system ran that kind of pressures. I guess I never really thought about it.
Eric
Old 07-14-2011, 01:54 PM
68400BIRD 68400BIRD is offline
Try
www.pirtekusa.com
Old 07-14-2011, 02:27 PM
sweetstang68347's Avatar
sweetstang68347 sweetstang68347 is offline
Check out page 28...
Should be what you're looking for.
Old 07-15-2011, 09:32 AM
Blake Foster's Avatar
Originally Posted by wmhjr View Post
For the pressure side you'll want at LEAST 1500psi. My pump drives 1450psi. On another note, I could tell you some stories about Russell and power steering fittings..... Suffice it to say there are no more Russell fittings anywhere on my car. Just removed the last one on Friday.
You should tell us. i have all Russell fittings and hose on my car.
i user tthe proflex black on all the return sides and their braided powersteering hose on the one pressure hose, i have had no issues other than one fitting that seems to weap ever so slightly. we have used Russell in the shop for 10 years and never had a problem???
Oh except that the proflex black hoes when used in a fuel system "SEEMS" to let the fuel smell through the hose ?? you only notice it when you park the car in a small garage
Blake Foster
www.speedtechperformance.com
Old 07-15-2011, 06:55 PM
mfain mfain is offline
I was going to send you to Woodward, but when I went to their website their "new" racks come with blue 2000 psi hoses -- my Woodward rack came with all black lines. The link below takes you to their site and the extract below is a discussion of why they changed hoses. Hope this helps.
Pappy
http://www.woodwardsteering.com/imag...components.pdf
Extract from link above:
High Pressure Hose PTFE core, stainless braid, soft cover Woodward Power Racks are now equipped with a new -6 hose rated for 2000 PSI working pressure. This hose replaces our former cloth-covered 1500 PSI hydraulic hose and its reusable type ends (shown at right for comparison).
IMPORTANT: There are many different brands of hose and reusable hose ends now in circulation, most of which are mutually incompatible. Because it can be difficult to tell them apart, racers in a hurry have been known to create mismatched hose assemblies from spare components. These may appear correct but can come apart under pressure. To prevent accidental mismatched field assemblies, WE USE ONLY PERMANENT CRIMP-TYPE ENDS ON OUR HPB6 PRESSURE HOSE. Although this hose conforms to the nominal standard dimensions of -6 stainless-braid PTFE hose, it also has an
abrasion-reducing fabric cover. The cover precludes the use of screw-on ends (the kind with a brass “olive”) which are intended only for uncovered stainless braid. Permanent ends are the ONLY type approved for use with this hose. Crimp tooling data will be made available to qualified hose shops on request.
Power Steering System Components
HOSE ADAPTERS, -6 o-ring to -6 AN/JIC male flare
STRAIGHT G180.............................................. ......3.25
45 DEGREE G145.............................................. ....4.95
90 DEGREE G190.............................................. ....4.55
BANJO HPB66MF........................................... ... 30.00
HOSE per foot HPB6.............. 7.95
STRAIGHT endHPB180......... 7.25
BANJO end HPB66.............. 32.50
90 end HPB190.................... 15.25
Assembly labor (per hose)...... 5.00
Old 07-23-2011, 01:26 AM
jwalk's Avatar
jwalk jwalk is offline
x2...xrp makes ps hose in black. Great quality
