Old 02-09-2012, 10:51 AM
I had TWO BeCool's leak -- in my Nomad -- never again.....
I use AutoRad now. Actually - I'd use ANYTHING over a BeCool...
Old 02-09-2012, 10:54 AM
Track Junky's Avatar
I'm running the $1200 BeCool also and so far its treated me and the car well. I'm running 620 hp at the crank.
Greg, which BeCool did you use?
Gaetano Cosentino
Old 02-09-2012, 01:43 PM
Whatever crossflow they sell for a tri five chevy... polished etc...
Both leaked in the exact same place -- where they GLUE their tanks on... I no longer use anything where the metal is glued... They call it epoxy -- I call it GLUE. No thanks to those tanks!
Old 02-09-2012, 02:36 PM
How long ago? 1956? Ha even Ron Davis was using epoxy 10 years ago. I agree though, I wouldnt buy a brand new epoxied radiator.
Old 02-09-2012, 05:55 PM
intocarss's Avatar
Now -- You said you have a SBC 400..... and they were notorious (wrongly so) for overheating. The reason that block had overheat issues was that people stuck SBC heads on 'em without drilling the steam hole in the head AND the gasket....
I went back and read that he has a 400 Bowtie block, Most of the true Bowtie blocks don't have the steam holes
A "crossflow" radiator will make a big difference too
Old 02-09-2012, 05:56 PM
69znc's Avatar
69znc 69znc is offline
Default I have had both Davis and now AutoRad
THe Davis and AutoRad both are excellent, and not inexpensive. radiators. I ran duel fans on both controlled by my ECM I got the larger diameter tubing in my new AutoRad. The target market for Davis seems to be a bit more industrial for HD racing and the AutoRad same quality and cooling but the extra touch to the street look and finish.
my 2 cents
Peter
Old 02-11-2012, 08:26 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Good ideas on the Radiators.
I had never dealt with a BT sbc before, and this issue was baffling.
Do you think that a "Cross Flow" radiator with the killer Mark VIII Fan would still be a viable option?
Those fans with a proper housing on it I believe to be about the strongest around.
Ty
Project, "EnGULFed"
1964 Gulf Liveried, Corvette, "Grand Sport"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
Full size 3 link and custom roll cage
315mm tires on rear, should fit the same on front. Worked to design a more effective shape.
"Chester's '65"
1965 Buick Riviera
Aiming for true PT Status with
the best available from the 70's and 80's
Old 02-11-2012, 08:45 AM
Fan CFM is only important when you're not moving... and it's more important if you're running A/C... and if you add an automatic transmission to that... then you have a lot of heat to deal with.
Personally I like dual fans -- and I've been controlling them on my cars with the Spal PWM fan controller. It adds cost - but really works well - especially if you're running A/C.
