Old 12-27-2011, 12:56 AM
Thomo5150 Thomo5150 is offline
PM'd.
Cleaning up the chassis rails today, I still have crossmembers to cut off. Should be on the chassis table tomorrow. So far 42 hours have been put into this project, keeping track so others mite wonder why Pro shops charge the money they do for this type of work.
Old 12-28-2011, 09:54 PM
More cleaning up of the chassis rails today.
Started to unpick the C5 chassis rail cuts offs today to make templates for the upper A arm and shock mount.
Old 12-30-2011, 08:14 PM
Fitting the frame rails to the table today. Quick mock up of the Corvette cradle and the passengers side frame. Hope the pic's explain how this will be done.I'll spend a day measuring and fitting both frame rails so they are aligned perfectly. Good thing the granno worker made the shed foor 100% flat.
This is where the frame will be notched to lift the cradle up approx 3inches. A crossmember will be added for strength and a radiator support, the engine is set back behind the center line of the front wheels.
LS6 engine
Old 01-02-2012, 05:20 AM
More work in the garage today. Progress is good coming together nicely.
Mock up of the frame rail.
Chassis rail needs to be notched 3 inches, that will give me the ride height I want.
Chassis is level, the torque tube is level, with the cradle being lifted 3 inches it looks like I wont have to modify the trans tunnel
The firewall will need a slight recess of about 4 inches
Old 01-03-2012, 05:39 AM
Final mock up today, everthing will work so let the fabrication begin, sorry about the poor quality pic's
Old 01-04-2012, 06:59 AM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
I am assuming you live in Australia?
Truck is looking great - should handle awesome!
I love the Vette/Commodore mixed running gear!
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 01-04-2012, 03:43 PM
Yes I do, I was building the One Tonner with the same running gear, a guy opened up his cheque book and brought the chassis. These are ther parts left over like the LS6 etc. F100 is a lot easier to do than the One Tonner.
Before
After
I think it will handle lol, look at the CG with the LS6 engine between the rails compared to the old cleveland. The final mock up for the front is done, i'll now make upper a arm brakets, crossmembers etc. Working on the rear rails today, its 3 weeks since I brought the F100 happy with the speed its coming together at........
Old 01-04-2012, 09:01 PM
Where you building that one ton over on ls1tech?
Old 01-04-2012, 09:20 PM
Yes I was, it had ZR1 brakes and the KB supercharger..........
Old 01-09-2012, 08:58 PM
Chassis table is finally square and level, started fitting the frame rails to it. Crossmembers are being fabed up, cradle and axle centre line should be in a centred tonight.
