Old 01-08-2012, 11:33 AM
John510's Avatar
John510 John510 is offline
I have a Speedtech sub with Ridetech single adjustable coilovers . Wouldn't trade it for anything.
[SIGPIC][/SIGPIC]
Old 01-08-2012, 07:28 PM
Blake Foster's Avatar
that's what we like to hear!!
your car is going to be driving this spring from he looks of it. you gotta be getting excited!!!
Blake Foster
www.speedtechperformance.com
Old 01-16-2012, 06:28 PM
hud697's Avatar
hud697 hud697 is offline
After talking with Roger at Speedtech today, im going with the torque arm set up on my Camaro. When somebody takes the time over the phone to talk to you about your car and your plans for the car, not knowing if you'll actually buy their stuff, says a lot for a company.
Old 01-25-2012, 07:42 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
I really agree on that, I have been in contact with Blake at Speedtech several times, really a nice guy and willing to provide technical support as much as possible whenever needed
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 01-26-2012, 03:51 AM
mild2wild mild2wild is offline
X3. You can't go wrong with Blake and Roger at Speedtech, or Brett and the boys over at Ridetech. Both top notch companies with top notch products and service!
Old 01-26-2012, 04:56 PM
BODYSHOPMARO's Avatar
BODYSHOPMARO BODYSHOPMARO is offline
HELL YA GOOD CHOICE SPEEDTECH PRODUCTS ARE AMAZING I LOVE MY SUBFRAME CANT WAIT TO DO THE REAR PLUS JAYS CUSTOMER SERVICE IS SOME OF THE BEST I HAVE EVER SEEN
Its only money/ 68 camaro/ Rich Sliwinske(PRECISION ENGINE AND MACHINE) 447 ci ERL sleeved/ landspeed development ported heads L92s/speedtech subframe/DSE mini tubbs/
Old 02-23-2012, 07:59 PM
GRob GRob is offline
Do you need to get the AFX spindles with the Speedtech front end to get all the benefits of it? If you don't, what spindles does it use?
Also do you offer the TA with a 12 bolt housing instead of the 9"?
Thanks,
Rob
Old 02-23-2012, 08:53 PM
makoshark makoshark is offline
Originally Posted by SR71 View Post
you can't go wrong with either.
I was in the same boat a couple of months ago. I went with a mix of both with a little sc&c sprinkled in. then a little of my own customizing.
I kept my stock sub and added a speedtech chicane kit with 5" stroke ridetech tripples and ridetech 2" drop spindles. these were bolted up to modded sc&c arms. I had to uses the chicane double shear lower mounts welded and bolted to the bottom of the lower arm. I also had to clearance the lower around the shock body and res line since it went through the coil spring mount. the adjustable sc&c uppers are the shiz. all of this fab work allowed me to run a 5" stroke shock with a 12" spring.
the rear is the speedtech tq arm with the exact same 5" stroke shocks. the speedtech kit is set up to use a 4" shock so I had to add an extra tab with one additional bolt hole onto the control arm brackets to get the ride down to where I wanted it.
....and where I wanted it is down to the top of the 19/20 wheels. this was no easy feat with a 27" front and 28" rear tire. the bottom of the sub is at 4" off of the road. because of the weather, I haven't gotten to drive it anywhere other than to the muffler shop. so I haven't had a chance to start dialing it in.
all I can say is that it looks absolutely WICKED. the stance says F@%& YOU!!!
if you have no fab or welding skills nor the equipment to do it with, you will be better off sticking with a complete bolt in system. but there is a sense of accomplishment from planning and executing your own set-up.
don't you just love it when a plan comes together???
I want to see some pics of this car Also would like to see exactly how you achieved the 5" stroke coilovers. I'm about to install coilovers on my car also and was looking to achieve the same results as you.
Old 02-24-2012, 04:14 AM
Supporting Vendor
I believe he used the Chicane kit which moves the upper coil over mount up in the vehicle and makes it a ring mount (opposed to the stock style post mount).
The Chicane kit is quite nice, but please don't think a 5" stroke shock will give you additional suspension travel. The front can only move as far as the physical parts will allow (especially bumpstops if you have them). So you can take a 5" stroke shock, or a 3.5" stroke shock and have exactly the same suspension movement at the wheel.
Skunk Werks
Ridetech
www.ridetech.com
Old 02-24-2012, 08:08 AM
Thanks,
Rob
No You do Not need the AFX spindles. if you use the Speedtech Subframe it also has the guldstrand mod built in if you decide to use the shock height spindle. so you have options.
The TA is available for a "Factory" 12 bolt.
Blake Foster
