So having moved-in, that's where the fun really began. With the dry sump tank situated and all the parts away being hard anodized, I decided to get busy again on the wiring. That lasted all of half a day before I got fed up with how things were fitting. I had elected to run my engine harness through the tunnel since one of my main goals was to keep as much plumbing and wiring hidden from view. It seemed I was working "up-hill" trying to make each leg of the SpearTech harness reach and also having to run some really tight corners. The driveline angle built-into the Art Morrison clip is about 4deg so raising the trans tunnel and creating a slightly larger opeingin in the firewall for the trans would give me some more options.
So reluctantly, we pulled the front-end including the engine and trans again.
To be clear - this was not the fault of the harness -
John @ SpearTech had designed the harness exactly as requested and it came out great. Similarly there was nothing wrong with the Art Morrison setup, I had just elected to run less of an angle, closer to 2deg. Since we could not drop the front of the engine lower due to the dry-sump pan clearance at the rack, we will raise the trans. With the earlier move to the AM engine mounts, that extra 1/16" thickness helped with some issues (like exhaust and pan clearance) but showed up in other areas like the engine-to-firewall / tunnel area. Not a big deal if you are running a stock firewall but in our case, too much work had gone into this to not stop and get it fixed now.
Eric is the newest addition to the BOS team and is a fantastic fabricator. We had Eric cut out and create a new trans tunnel with more clearnace for everything.
Here's Eric doing his thang....
The real joy - doing all this on an already painted car...ugh! Jesus refinished and sprayed the firewall and once out of the booth we re-undercoated the tunnel with Wurth StoneGuard.
Prior to reassembly we took the opportunity to locate and mount our 4-port a/c bulkhead, ready for the Vintage Air and Jesus & i took care of the shifter cutout and mounting. With the engine and trans back in, we were finally getting set to go forward again!
