Old 04-25-2012, 01:32 PM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
Originally Posted by Macbuick View Post
So i started to work again on the Buick, but things can't always go right !
My Ron Davis Radiator doesn't sit right in his upper mounts in the upper radiator support ....
I bought it from TA Performance, so it should have sits in a Buick !
Looks like you need different rubber isolators. Here are some that I bought and what came with my 68 GTO.
Looks like you need the long ones with the big openings which I cannot find.
Love the new garage! Great work space!
Jon U.
1968 GTO - SC&C's suspension
1967 911 - a few modifications
Old 04-25-2012, 11:31 PM
Macbuick's Avatar
Macbuick Macbuick is offline
In fact one of the lower rubber had moved and that why the radiator was not in the right place...
I didn't noticed it whan bolting the upper bracket
My rubber are right I wanted to replace them but they where out of stock by TA Performance (Buick specialist), i will check on my El Camino if chevys are the same.
Thanks anyway for your help !!
David
[SIGPIC][/SIGPIC]
72 Skylark & 68 Pontiac Catalina+ 71 El Camino
Old 05-02-2012, 10:35 AM
Macbuick's Avatar
Default connected.....
so the intercooler is connected, i cut all the tubing to the right length...
Do you know of any small tool to make a bead, or rolled up at the end of the tube ? Is there only a Woodward-Fab Bead Roller Kit which can do it?
I cut some tubing which had bead on each side but now one side is missing his bead !
Any help will be welcome !!
David
[SIGPIC][/SIGPIC]
Old 08-29-2012, 11:45 PM
Macbuick's Avatar
time to fit the intercooler with some fabrications...
I had to cut the tubing and make some beads at the end of the tubes, I used a bead roller.
[SIGPIC][/SIGPIC]
Old 08-29-2012, 11:46 PM
Macbuick's Avatar
the jauge pod is in place =) fuel and boost pressure
next step , getting rid of the column shifter...
I had bought a tilt floor shifter column from a monte carlo (dixit seller) and I mixed the two comlumn using the monte housing in place of the Buick one...
job done....
[SIGPIC][/SIGPIC]
Macbuick's Avatar
with my modified Unimatic shifter,
I built a mounting box to place it under my console..
the welds are as is as they will be hidden
[SIGPIC][/SIGPIC]
Old 08-29-2012, 11:47 PM
Macbuick's Avatar
Koni shocks are in place as well as the SPC upper arms.....in place of the CPP ones.
next step the eletricity, MSD and fuel pump.....
[SIGPIC][/SIGPIC]
Macbuick's Avatar
sump tank is welded.....
I made a plate to bolt the fuel pump between the tank and the rear bumper...
I ordered a sandwich plate to place between the oil filter in order to have more holes to fit the oil pressure and T°....
[SIGPIC][/SIGPIC]
Old 08-30-2012, 06:58 AM
Really cool build! You're doing a great job.
Old 08-30-2012, 08:16 AM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Great looking build!
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
