Old 02-29-2012, 10:46 AM
Blake Foster's Avatar
Originally Posted by EBMC View Post
Just making sure! No problems activating it during aggresive driving?
only problem i encounter is the CRAZY wheel spin at about 150 mph.
you know mad max kind of power.
all kidding aside, no problems not very often you are slamming the shifter into 5th and could miss and hit "R"
plus where the button is it is between your thumb and palm.
works great.
Blake Foster
www.speedtechperformance.com
Old 02-29-2012, 12:23 PM
parsonsj parsonsj is offline
Default Stupid question
Will any of these shifters work in the stock console? (I'm new to Camaros).
John Parsons
Old 02-29-2012, 12:53 PM
Sieg's Avatar
Sieg Sieg is offline
Here's the one I've got: http://www.hurst-drivelines.com/?page_id=25
I'd say it's close to perfect with the exception of the leak/weaping issue which may be a one-off issue. I did shorten the plastic tunnel about 1" for additional shift-boot clearance. A stock rubber shift-boot won't work IMO, I sewed up my own naugahide boot.
Here's a pic without the shift-boot:
With the boot:
Old 02-29-2012, 01:22 PM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
I use the Hurst Blackjack as well (with stock console), and have had no issues whatsoever.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 02-29-2012, 03:04 PM
Sieg's Avatar
Matt - Did you cut out the Tremec shifter seal and install it on the Blackjack?
I wondering if I have a unit with a manufacturing defect, Jim at Hurst DL's has been great and offered a new unit at N/C. I just haven't had time to tear the console, cut the carpet and access the shifter.
Old 02-29-2012, 03:18 PM
I've seen a minimum of 4 people already with the shifter leaking issue.
Old 02-29-2012, 05:10 PM
Sieg's Avatar
Specifically the Blackjack?
Old 02-29-2012, 06:24 PM
Not sure... All 56 mags though.
Old 02-29-2012, 09:46 PM
BBPanel BBPanel is offline
Originally Posted by 67ragtp View Post
Check out White lightning, adjustable spring rate, handle can be clocked in all kinds of different directions, short throw. Nice piece of hardware, I like it!
http://www.americanpowertrain.com/Sh...echanisms.html
Rich
That sure does look like Red Roberts (McLeod) shifter, the one on the Vette TKO - wonder if they are re-branding it or copying it? I have one of Red's shifters in my 66 Nova (T56) and even though I haven't driven it yet it feels great. The 2 x 2 offset put the shifter exactly where it needed to be.
Old 03-01-2012, 11:12 AM
6D9 Matt's Avatar
I have a good friend that has a shop here, so he did all the work. He didnt say anything about any of that though, seemed to be a pretty smooth conversion with the console, etc.
Will you only notice the leaking if you take off the boot, etc? Now Im worried about my mine leaking. Havent noticed anything though...
'69 Camaro
416ci / T56 / 9"
