Old 04-09-2012, 11:51 AM
onevoice onevoice is offline
Originally Posted by garickman View Post
Here is a few pics of my chassis for my 1967 Chevelle. Someone over on PT suggested that I need trailing arms on the rear lower control arms. Any input or advice you can offer would be much appreciated. If interested here is the link to build thread with alot more pics.
https://lateral-g.net/forums/showthread.php4?t=34813
The top link needs to be triangulated (like a vette) or an upper trailing link has the same effect. Something needs to take the brake reaction forces at the top of the spindle. Picture trying to rotate the spindle looking at it from the side, the lower link will resist all the force by twisting. It can't handle it.
Old 04-10-2012, 10:58 AM
Do what you want, but a viper and corvette both have upper links that provide fore and aft locating of the spindle (both use A arms). All IRS's I have ever seen have either triangulated control arms (a arms), trailing links, or trailing arms, or a combination thereof. Nobody makes an IRS rear with a single, unbraced upper link
I would take their engineering over a street rod builder.
Old 04-10-2012, 06:20 PM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
... Taking the shock off the lower control arm has reduced the load on the spindle. .... The push rod mount on the top of the spindle is being redesigned to take some of the angle out of the push rod. He wanted me to add (as some people have already pointed out) it is difficult to know exactly what is going on by just looking at the few photos I have posted.
I disagree that it will take load off the spindle. It has changed the loads, yes, but not taken them off. The lateral and fore aft loads are still applied through the spindle but now a moment has been added about the attachment points with now a shorter moment arm. In addition, the "vertical" load from the shock / spring has now been moved from the lower ball joint to the upper ball joint. However, the ATS spindles are 6061-T6 and OE Vette spindles are A356-T6. So you are gaining some strength and elongation there which is a big plus. Whether or not you'll have an issue depends on so many other things like vehicle weight and distribution, tire diameter, and on and on, that really no one can tell you for sure if this is an issue within pro-touring operating use.
Good to hear the push rod angles are being optimized. It was very hard to tell from the pics whether or not it could be an issue, but it looked like there was a good chance that at least you'd see undesired variation in spring rates.
I think the OP was mainly concerned with function, and not whether or not this was the optimum IRS style. It will work without toe links. Yes, most other IRS's have a toe link, but there are not many "swing arm" style IRS's out there, but there are some good ones. Check out the previous BMW X5 rear suspension for instance. Quite different from the OP's suspension and does have two upper links, but not really a toe link. Nor are the upper links all that effective at completely limiting roll / twist as they have rubber bushings.
Lots and lots of things that may or may not achieve ones goals.
Good luck to the OP and his builder!
Brian
1968 Pontiac Firebird
1989 Ford Mustang
Old 04-11-2012, 08:29 AM
Not sure what you are getting at here. I wasn't talking about toe links. I said all IRS suspensions control the fore and aft movement of the upper part of the spindle from the top , think constraint of caster. All IRS suspensions also control the toe, whether with a toe link(like a vette or viper), or the physical layout of the locating arms like this design.
From the side view, the spindle as designed only resists rotation from the lower control arm. This is no way to design a performance suspension, unless the lower arm is super strong, because the forces will constantly be twisting the lower arm.
This design would be much better by spreading the upper link inner attaching point into two pieces, making it an A-arm. Same effect by using an upper trailing link.
Also, I'm not a big fan of modifying such a critical part as a spindle to use the steering arm location mounts as lower suspension mounts. Without obvious overkill design, it is foolish to do so without engineering analysis by someone familiar with the design and strengths of the original part.
Old 04-11-2012, 08:39 AM
bdahlg68's Avatar
This is what I was getting at. I agree it could be better designed for performance applications. That just didn't seem to be the intent of the original question.
Brian
1989 Ford Mustang
Old 04-12-2012, 11:55 PM
Vince@Meanstreets's Avatar
I prefer a short arm long arm configuation myself.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-13-2012, 07:07 AM
Both of those setups have inboard brakes
Big difference in the spindle loads.
The lower is similar to a jag setup, and doesn't even have an upper link, it uses the axle as the upper link. A design from the 1960's, that wasn't known for great handling even back then, isn't something I would emulate for a modern scratch built performance vehicle.
I don't know who designed the other one, but it is not a modern, robust design. Fairgrounds street rod it is fine, otherwise, get something that incorporates the best design practices. Those IRS designs are the equivalent of updating a 30's solid front axle with an independent 50's design that uses kingpins. Or comparing a DSE front subframe to a street rod mustang II setup.
A bad IRS is worse than a good design solid axle.
Edit: I just saw the linked picture, and I stand corrected, that is obviously a recent rear axle. Explorer maybe? It is however very different from the OP design. The linked pictures show a lower control arm that is VERY wide to take the loads involved. The inner mounts of that arm are about twice the diameter of the brake disc, probably 18-20" apart. The lower arm attachment to the spindle is also spread apart what looks like a brake disc width, call it 10 inches, and the attachment of the arm to the spindle is very close to the axle center-line, minimizing the moment. In short, that arm is designed to take the loads I was saying the OP design isn't. Certainly not the same case as using a modified front spindle with the steering arm mounts as the lower arm attachments.
Old 04-13-2012, 03:53 PM
well you said it....
lol
Dealer for
NEVER FORGET -11
Old 06-19-2012, 12:48 PM
ProTouring442's Avatar
Of course, Jag moved the brakes outboard later...
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
