Old 05-11-2012, 10:13 AM
inkman101 inkman101 is offline
Default 305/40/18 on a 9.5 wheel ?
Hi, anyone running a 305/40/18 on a 9.5 wheel?
Thanks Pete
Old 05-11-2012, 10:17 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
That seems a too wide for a 9.5" tire. I'm pretty sure the tire specs on a 305doesn't warrant a 9.5" tire. If you mount it, there would be alot of tire going inward, so to speak, from the rim not being wide enough. I'm no expert though. Just my $.02. I previously had 305's on an 11" rim. Not to mention a 40 sidewall for a 305 is pretty tall.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 05-11-2012, 10:40 AM
Flash68's Avatar
Flash68 Flash68 is offline
Nitto's size chart recommends at least a 10.5 wide.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-11-2012, 06:42 PM
Nitto says 10 to 12, will a 1/2 make a big deal? They are exactly what I want as far has size goes 27.75 high. I'm looking at Centerline rims and they only go up to 9.5.
Pete
Old 05-11-2012, 06:51 PM
Track Junky's Avatar
A 9.5" wide wheel isn't 9.5 wide. Measured width is what tire manufacturers go by. My guess is a 9.5" wheel is around 10 1/4" measured width. Recheck fitment specifications for specified tire and then measure from inside of lip to inside of lip on wheel.
Gaetano Cosentino
Old 05-11-2012, 07:48 PM
It will probably work but I wouldn't go outside a tire manufacturers recommendation. That could bite you at the wrong time.
