Old 03-09-2006, 05:21 AM
CAMAROBOY69 CAMAROBOY69 is offline
Originally Posted by Payton King
Low fluid level or you need a new filter. When was the last time the fluid and filter was changed?
The fluid needs to be checked at operating temp while the car is running. If it has been more than 30,000 miles I would change the filter.
Thats exactly what I was going to say. Its very common for the rear seal to even leak in the winter because of the cold. I just went thru this with my truck. Put it in gear, nothing. Checked the fluid. It was low and it fixed the problem.
Probably not the filter.
Adam_______Offical Car Name "ILLUSION"
383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels,Hydratech Hydraboost
ILLUSION Website
--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
