Old 08-30-2012, 10:02 PM
snappytravis's Avatar
I built this and the drivetrain sits at 2.5* down.
I'm using Moroso solid motor mounts and Energy urethane rear. Standard height subframe mounts.
any vibration with the solid mounts? what pan, I have autokraft pan with energy mounts and it's super close to rack,
Old 08-30-2012, 10:18 PM
Sieg's Avatar
Sieg Sieg is offline
Milodon pan, my motor is well balanced and I never felt vibration was an issue, some people are more sensitive to vibration than others, especially on motorcycles. My driveline angles were a vibration issue though and 4* shims helped that. No regrets with the solid mounts, I like the positive clutch/throttle response. No rack, Lee's close ratio box. I have about an 1/8" clearance on the tunnel/shifter right rear bolt no contact issues.
Old 11-25-2012, 06:34 PM
blazer1970 blazer1970 is offline
I bought my T56 Magnum kit from American Powertrain, the kit came complete.
I went with the hydraulic throw out bearing also.
