Old 07-20-2012, 08:22 AM
GPR's Avatar
GPR GPR is offline
The snubber brackets are not mounted in the same place on the frame rail so Brian removed them so we could install the cradle for the TCP rear suspension.
Cradle bolted and welded in place
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 07-21-2012, 08:27 PM
GHOSTDANCER GHOSTDANCER is offline
Subscribed. Can't wait to see how the Dynacorn body works out.
Old 07-25-2012, 12:49 PM
GPR's Avatar
GPR GPR is offline
The cradle is supposed to bolt to the pinnon snubber mount but there was no holes and it was off center a little.
Brian welded a bracket
Brian decided to improving the welding a little
They welded the other side
Rusty Gillis
Port Richey Fl
Old 07-25-2012, 02:50 PM
GPR's Avatar
GPR GPR is offline
Test fitting the TCP front and rear suspension with Wilwood brakes
Rusty Gillis
Port Richey Fl
Old 08-11-2012, 12:14 PM
GPR's Avatar
GPR GPR is offline
If only the doors, fenders & hood fit like this.
Rusty Gillis
Port Richey Fl
Old 10-07-2012, 11:17 AM
GPR's Avatar
GPR GPR is offline
The deck lid fit great but the doors, fenders and hood are another story.
Once the fender apron holes were modified to get the fender back so there was not a large gap at the windshield and front of the hood there was not enough gap at the door.
The hood is to wide at the back and will need to be trimmed
Rusty Gillis
Port Richey Fl
Old 10-07-2012, 08:41 PM
Looks good so far can't wait to see it done.
Old 10-20-2012, 10:00 AM
GPR's Avatar
GPR GPR is offline
Brian had to grind and add material to the door
After grinding
He also had to do the same to the front
Rusty Gillis
Port Richey Fl
Old 10-20-2012, 10:55 AM
GPR's Avatar
GPR GPR is offline
The left vent window would not fit so Brian had to drill out the spot welds and bend the sheetmetal a little to allow the vent window to go in.
The bracket on the inside of the door where the bottom of the vent window attaches was in the wrong place and had to be moved
Rusty Gillis
Port Richey Fl
Old 10-20-2012, 11:22 AM
GPR's Avatar
GPR GPR is offline
Brian had to narrow the hood than weld a strip on the back side
Rusty Gillis
Port Richey Fl
