Old 03-16-2006, 01:00 PM
68protouring454's Avatar
Default lt-1
you can use the bellhousing from the lt-1 and go directly to the 2 peice rear main seal block, then get the conversion flywheel from mcleod,centerforce,ram,spec and also the pull off style clutch
BUT in your first post it says ls-1 t 56 which has a longer input shaft so you will need the mcleod modular belhousing (which comes with adapta pilot bushing) so it spaces the ls-1 t-56 the correct amount off the 2 peice rear main seal block, then you will need whatever 168 tooth flywheel for your motor(depending on internal or external balance of motor) and a ls-1 style push on clutch.so what year tranny is it?
if its 93-97 you need
1.tranny with bellhousing
2.153 tooth flywheel for lt-1 t-56 to 2 peice rear main block and lt-1 hydraulics
3. pull off style lt-1 clutch which is 10.5 big and not desirable for high hp/tq
if its a 98-03 t-56
1.tranny
2.mcloed bellhousing for retrofit of ls-1 t-56 to 2 peice rear main block
3.a comparable clutch for set up, a twin disk or a 12 inch single disk
4.stock ls-1 hydraulics which ls-1 has a hydraulic throwout bearing
again call ats
Old 03-16-2006, 01:01 PM
You can't use the LT1 bellhousing for a few reasons:
1. the input shaft on an LS1 style T56 is 3/8" longer than a T56 from an LT1. The input shaft would be inside your crank with an LT1 bellhousing.
2. The LS1 uses a hydraulic throw out bearing, and the LT1 uses a hydraulicly actuated clutch fork, and bellhousings are setup accordingly.
The tunnel on the A body is too small for a T56, hence the tunnel cutting. There is no way it will fit in there as is. Once the new tunnel is fabbed and welded in, you will still need a shifter hole.
Tyler
Old 03-16-2006, 02:07 PM
projekt70chevelle projekt70chevelle is offline
Well what do I need to buy from you to make this work? Dont forget the prices
Old 03-16-2006, 03:39 PM
Default dude
you need to figure out what year tranny you have then we can help or tyler can tell you
Old 03-16-2006, 05:13 PM
I Pm'd tyler what I got... But I dont have it yet the guy went on a cruise so I guess I still got time to back out... Its out of a 2000 ss camaro. But he did offer me his other ls1 complete for $1k, but it has a knock... So if I go the ls1 route I wont have to worry about adapters just cutting and rewelding.
But I guess it would be better, I mean easier and cheaper to go with the 93-97 trans setup
