Old 08-01-2012, 03:17 PM
hotwhls's Avatar
hotwhls hotwhls is offline
My first hot rod was a 1972 chevelle and I really miss that car. But I always thought of the chevelle as the best muscle car "my oppinion" and I always thought that is should have a BIG BLOCK to take up the room in the engine compartment. Just build that 396 it looks cooler than an LS motor that everybody else and there brother has. Well anyways the car looks great and just drive it and enjoy it and build it whenever you have the extra funds
Old 09-04-2012, 07:37 AM
barrrf's Avatar
barrrf barrrf is offline
I have since installed 3 point seat belts. and reinstalled the a-pillars and dash board uncovered. I cant get the dash pad into the upholsterers until the 12th. So once thats done I'll slap the dash back on and take some shots. I did however, color match the tired old pitted tail light bezels and polished the plastic. Not sure if I like it yet or not.....or if I do like it should I repaint the black inside of the bezel or not.
Color Matched
Not
Progress is slow on this car - Im too busy driving it to work on it. And heres a pic for photography buffs (shot with Canon T3i)
'69 Chevelle Malibu LSX370, 4L80E, Brembos, hydroboost, 12 bolt, c/os, etc.
You can call me Bart
Old 09-20-2012, 05:21 AM
barrrf's Avatar
Had the dash pad covered and stitched.
Only good pic I have of it now. Also shown is , gauge bezel painted, metal dash part painted silver along with column, A-pillars covered with soft touch vinyl (really nice stuff), kick panels redyed black, vents painted black, tach reloacted from top center of dash. Im going to call the dash area done for now until I can fund VHX gauges, new carrier, and ididit column. My next thing to do is find a nice steering wheel. Then in a couple weeks I'll start on the door panels - I figure this to be a good month long project.
I know the stitching isnt perfect. But thats fine, I wasnt expecting it to be.
Old 05-20-2013, 10:03 AM
barrrf's Avatar
Update: So I strayed from my original path of just replacing the core support and cleaning up the front suspension with some powder coat and new bushings. Whilst I did replace the core support, I also replaced the A-Arms and springs in the front, new alternator, lower alternator bracket (was missing), new CPP 3" springs in back, body bushings, and seats.
4/15/13 - Everything removed from drivers side. Gonna clean up the frame and paint before putting new stuff on.
Gross old stuff on the ground. It was at this point I decided to buy all new stuffs. I waffled a bit. But I got really frustrated with trying to remove the old bushings, so I chucked the a-arm and hit up ebay.
Rats nest behind the firewall. This is how it came to me. Its the horn relay (life of the car apparently) and the voltage regulator. 2 things that are curious about the factory build/wiring. 1.) The horn relay needs constant 12v power. Without it the car has absolutely 0 power. None. Cant even turn it over. 2.) All of the passenger side wires run in front of the core support on the outside of the car. I believe all of the wires were run and the connectors put on after that. Because I could not pull them back through - the connectors were too big. I had to cut 5 wires and put them back to together as a semi temporary fix.
4/19/13 - Grille, headlights,header panel, ect removed
Still 4/19/13 - Everything is off. Reassembly can begin.
4/30/13 - New A-Arms with Energy Suspension Bushings and Proforged ball joints with Hotchikis 2" drop springs. Im impressed the sway bar link are roto-joints. Not bad for cheap a-arms. .
*Disclaimer - I really really wanted UMIs with tall BJs but the coin wasnt there and I wanted to stretch my buck a bit further. So I bought these CPP A-arms for $279 shipped. I bought the Proforged BJs at the same time with the intention of swapping them out immediately. When the arms arrived, I disassembled them and installed the new bushings and ball joints. I reused the original ball joint grease boots because they fit better then the Proforged ones for whatever reason. I also painted them silver - just because. What I did leave however, is the sway bar end links. The lower connection is a roto-joint as opposed to the OG bushing method.
Still 4/30/13 - Caliper bracket - steering linkage shot
5/4/13 - Painted new core support to install.
Another shot of some more stuff installed. Also, some wires just hanging around.
Some poly body bushings to show. Yes theyre on the whole car and not just right here.
Brackets and header panel reinstalled
Filler panel and headlights reinstalled. Used all new headlight bucket hardware and springs. Decided against installing retrofit projectors at this time because I just wanted to get the car on the road. Will install later - requires cutting headlight buckets and core support. So I just put in H4 highs (replaces T3s) and installed new relay harness. OEM wiring sends all headlight power through the headlight switch - makes for dim lights. Relays are the way.
5/5/13 - Forgot to take some pics along the way. So in this pic I have the fender wells reinstalled (painted silver), core support bracket reinstalled, and dirty **** reinstalled. You can also see new CS130 Alternator. It bothers me to no end to put old **** back on, but, this isnt an unlimited budget build. So I make due. I couldve cleaned some things up I suppose but I was in a damn hurry.
5/5/13 - Had old Edelbrock Q-Jet 850cfm carb on there. I bought this 770cfm Holley Street Avenger to use instead. Holy off idle hesitation batman. Took some research and some parts but it is tuned up and makes way more power than the Q-Jet did.
But I learned a lot about the Holley carb. Most people said the lean condition I was experiencing (popping out of the exhaust, off idle hesitation) was caused by vac leak or improperly set accelerator pump. So this gave a place to start. I removed the accel pump diaphragm and checked the primary squirter size. Everything seemed to be good there. I reinstalled those parts and set up a slightly more aggressive pump cam with a longer squirt duration. Still hesitated pretty bad but I could push through it and the car would move. So I bought a vac gauge and set the idle mixture screws, then the curb idle screw, and made sure the float levels were correct and also dialed the fuel pressure up from 4 1/2 psi to 6psi. Still a mean hesitation. Finally I decided to look at the primary and secondary metering jets. 68 and 76 respectively - yup, car is lean. Bought new jets and started with 72/76 combo. That almost did the trick - still a slight hesitation under light throttle. Went up to 76/82 - BOOM! MONEY! Now just waiting on my AFR gauge to arrive to see where I sit.
barrrf's Avatar
And on Friday 5/17 - New Seats and Wheel installed. The wheel is a flimsy piece of crap and I need to find a better one (thats my personal opinion about this particular wheel made by Forever Sharp. They may have better wheels I dont know. But the adapter parts that came with the wheels are awesome). I'll make due for now. The Cipher seats however, firm, good bolstering, solid construction - not bad for $340 shipped. Im am slightly concerned about the sitching - we'll see how well it holds over time. The biggest hit was buying the Planted seat brackets. $140 each. Theyre very nice brackets though.
And the lowered shots -
Forgot to remove SS plate. Oh well.
For the most part, everything went ok. Only one bolt on the passenger side lower A-Arm had to be cut off. Mostly everything lined back up which is lucky considering the nature of aftermarket replacement sheet metal. I had one issue with the headlight wiring, it was a ground so easy fix. Then I mentioned the no power thing - that had me stumped. I initially thought the POs terrible wiring job was the culprit - there was a random blue wire tied to battery +. Turns out random blue is pretty important to the life of the car so I ran a new red power wire to the horn relay.
So in the end, I have some nice new parts. Jury is still out on if it handles any better. I'll do my best to describe the before and after seat of the pants handling.
Before - car seemed to roll slightly then bite hard in sharp corners
After - car doesnt seem to roll. Seems to effortlessly glide through the corners. Giving the illusion the car isnt biting. Handling seems worse but I have more confidence in the corners.
Old 05-20-2013, 12:11 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Bart, looks like you been logging in some man hours on the car? Keep up the good work...more pics.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 05-20-2013, 12:26 PM
barrrf's Avatar
I figure about 80 or so hours including all of the blasting I did to the old stuff I removed/painted/reinstalled during the process. I dont mind reinstalling freshened parts but putting that plastic fan shroud back on made me want to vomit. still does in fact.
Old 05-21-2013, 05:18 AM
214Chevy's Avatar
That's a quick fix. Just make you one out of sheet metal. Bend it into an arc, so to speak, then add some bead rolled lines in it for strength. Voila!! There you have it. That's what a buddy of mine did some years ago, but he no longer owns the car anymore. Otherwise, I would get you some pics. You're gonna have to make your own since there isn't anything out there on the market. Either that or switch to an electric fan.
'68 C10 swb
'72 Chevelle
Old 05-21-2013, 05:22 AM
barrrf's Avatar
E-Fans and hydro boost (Astro Van) are next on the list of things to do. Ive been looking at some of the sheet metal fan shrouds on ebay - some do not look terrible. Some look like ass.
Old 05-21-2013, 05:25 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
It's looking better and better!
Curtis
