Old 08-08-2012, 04:46 PM
Cole Cole is offline
Banned
Originally Posted by Mkelcy View Post
Man, this is like pulling teeth.
Have you installed the clutch, flywheel, Z bar, linkage, pedals, adjusted everything, fired the engine and determined that there's an issue - i.e., that you can't disengage the clutch and/or get a good clutch pedal release point with things as they are now?
It also looks like the transmission is clocked, as if you had an adapter plate intended for a third gen or have the transmission mounted in the wrong set of holes in the adpater.
Finally, have you checked driveline angles. There appears to be a LOT of room in your transmission tunnel.
Thanks for you help but I think we are on a different page.
Originally Posted by MarkM66 View Post
Go hydraulic.
Doing it!
Negative as in footwell clearance for throttle function.
FWIW - Here's my '69 SBC w/ T-56 Mag.
W/ Moroso solid motor mounts.
I did a fair amount of massaging of the firewall to clearance the QT bellhousing.
Is this a hydraulic setup. Thank you for your help. Appreciate the pictures..
Old 08-08-2012, 04:56 PM
This is a common problem when you use a clutch fork that is the HIGH STRENGTH version.(Something to that effect) A stock fork is the only one that works and will be plenty as I use it.
#2 If you changed the relationship of the throw out bearing by using an adapter, that could also be your problem.
Old 08-08-2012, 05:45 PM
Sieg's Avatar
Sieg Sieg is offline
It's manual with a McLeod adjustable throwout. I've been very satisfied with feel and modulation. My concern with hydraulic is the car may not get driven for 4-5 months during the Oregon winters and I've heard enough about leaking slaves associated with lack of use that I opted for old school.
Old 08-15-2012, 02:21 PM
69Pressurized's Avatar
69Pressurized 69Pressurized is offline
As previously stated by Vegas69,the problem is your clutck fork. We have run into this problem many times over the years in lots of installs. The clutch fork you are looking for is GM part# 03892632. That is what we always use and have had success every time. Hope this information helps.
Old 08-19-2012, 08:55 AM
Banned
Thanks Todd.
Appreciate your photos, they have been a great help.
Thank you for the part #.
Old 10-17-2012, 10:24 AM
Tweaked Zed's Avatar
Tweaked Zed Tweaked Zed is offline
And be sure to set up the clutch pivot properly, if it is adjustable. Measurement from block to pivot ball should be 4.75" according to my instructions. The measurement worked perfect for me.
1969 Camaro SS, Maggied LS2, T56, Fab 9, G-Link, Speed Tech sub, Fikse FM10s....sold
1963 Nova SS, 383sbc, 700r4, 3.73 8.2, CPP 4wdiscs, Cragars, mostly driven by the GF.
1973 Camaro RS, 454 BBC, T400, 3.73 8.5, newly acquired full resto, next PT project.
1995 Camaro Z28, 440ci SB2.2, T56, 9", PB 9.70 @ 142mph - 2011 Hot Rod Drag Week 2nd place BB/NA
2009 TBSS 2WD 3SS, cam, exhaust, 450rwhp DD.
Old 10-17-2012, 10:46 PM
Banned
Too funny.... I was talking with Vegas 69 the other day. He made the same mention and we have been looking into it the last couple days. I'll keep ya posted.
Old 11-09-2012, 06:10 PM
Banned
Thanks gentleman both you and Todd nailed. Josh @ JEP installed the longer pivot ball and it seems good to go.
Gracias
Old 11-09-2012, 07:25 PM
Ron in SoCal's Avatar
About time
Ron in SoCal
69 Camaro in progress
Old 11-09-2012, 09:10 PM
Sieg's Avatar
Good news!
