Go Back   Lateral-g Forums > Events > Track and Driving Events
Old 08-29-2012, 12:28 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
Originally Posted by Matt.A View Post
Hey Brett, weren't you running on R888 tires too
nooooo. not that I remember. I think I was using a new KDW2 compound. Big hush hush around here. I had to use some water spray to keep them cool though.
That's all I remember and/or that Im allowed to talk about.
#5 -- Make sure you don't piss off the starter....
I see how it is........................................What that hundie was not enough for you. What does a guy like me have to do to get you to like me?
Old 08-29-2012, 12:35 PM
I was able to shave 10% off your times... did you want more? Time is money buddy!
Old 08-29-2012, 02:10 PM
Shiat 10%.....? I didn't know. That's good stuff and that must have put me into Todds' ZL1 time bracket.
Thanks, I will have to pay more attention to the "Go! Go! Go!" next time.
Old 08-29-2012, 08:51 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
I started typing out something about "special tires," then I thought better of it.
Let's just add that if someone is running faster than you with KDW2s then the best excuse is to claim that there is something weird going on, if you don't call out the tires themselves, then you have to say that they have some kind of magic spray that makes them stickier. Not water, definitely not water. Can't remember who I heard that one from
I found out water helps most street tires, as their performance starts dropping off pretty quickly once they get in the high 120s to 130s (I think)
Will I be bringing water to spray on my tires? Probably not. I think it is cheaper to pay Greg off than to buy a spray bottle, I'm only looking for half a second, which should only be a $20, right?
Matt
Old 08-29-2012, 10:02 PM
Matt
You kiss ars, you must be getting some BFGs in your future.
However, you are absulutely right about going down an ugly road with my tire comment. I should have never gone there.
So, with that Im out on this joking around and making fun of ASCS.
Old 08-29-2012, 10:25 PM
Originally Posted by BANKO View Post
Hey Guys, I don't think this currently exists, but thought it would be great to get some insight into what one should prepare for in anticipation of the event. Read the tech rules and got those items covered, but was thinking about fuel, replacement parts, tools, etc. Any feedback would be most welcome.
Thanks!
In all seriousness, ASCS is a fun event. You get a great experience with the ability to really test your driving skills and to test the performance of your car.
I was hoping someone would eventually chim in about what a first timer could bring or prepare, but my joking around took front stage.
As I give it some thought, here are some of my opinions about preparing for this type of an event.
Im not sure how freesh your car is but here are some pre-event stuff:
1. Make sure all you fluids are clean, full and new. Especially your brake fluid and power steering fluid.
2. Check all suspension bolts and key mounting bolts for tightness and condition. While you are at it do a visual inspection of all suspension parts for any strange issues, such as rubbing, cracking ect...
3. It goes without saying to do the same, as above, for your engine and drive line components.
4. Make sure all your interior components are secure, and not able to move around during hard braking and turning. Especially inspect your driver seat, seat belt, steering wheel and foot control pedals.
5. Fill up your tires to the street recommended pressure. That way you have enough to let some out at the track if needed.
Just my 2 more cents here for what to bring to the event:
1. Try to bring a little extra oil, power steering fluid, coolant, trans fluid and brake fluid. As the track seems to find a way to make these come out.
2. I always find it helpful to bring some type of cleaning supplies for windsheild, helmet ect... Also nice to have around if you have a problem and you need to clean your hands.
3. Some work rags and a towel or pad to lay on the ground if you have a problem.
4. A few basic tools that could be used on your most critical items. Don't try to over pack your tools unless you have the room. PITA to lug around and typically with such a great group of people someone may have what you need.
5. Bring a tire pressure guage so you can adjust tire pressure down to a reasonable amount based on your tire edge contact.
I know I could probably think of more, but this is actually my basic list I use for any event I attend.
Hopefully a few more will chim in.
Brett
Old 08-29-2012, 10:33 PM
SLO_Z28 SLO_Z28 is offline
Most street tires fall off hard around 160 or so, some lower. Watering down tires to cool them down on a hot day is a common practice.
I think Brett's comments are dead on and funny as heck, but in all seriousness there is a lot you should do before an event. I have to do some work and prep my car this weekend, I will try and take pictures and talk about what I do as a pre race inspection.
James F.
1974 Camaro Z28
Old 09-01-2012, 10:03 PM
Gandalf Gandalf is offline
Don't bother running 200 plus tread wear BFGs or similar. Just go right for the "exhibition class" tires. Run groups aren't based on classes. You can still run alongside your friends, and you'll be faster. If you aren't faster, no big deal, you're running in exhibition, and your times won't be recorded so no one will be able to make fun of you after the fact because there won't be any proof.
Matt
<cough>....you were saying Matt?
I'll add one more to Brett's list....
#5 - Bring your own camera if you are not in the big dog run group.
Seriously though - I had a blast at the most recent RTTC event - the actual on-coarse experience with the 3 separate events was a blast and even better to be sharing that experience with friends from here. Really looking forward to October!
G.
Old 09-03-2012, 07:22 AM
I'll add one more post to this great question:
Old 09-03-2012, 08:55 AM
Flash68's Avatar
Flash68 Flash68 is offline
Welder -- what an original post!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
