Old 04-23-2013, 06:53 AM
windycitychev windycitychev is offline
Default Project update
It has been months but I have some cool updates of the Chevelle, at this point the frame was ready and had been sent out to be mated back with the Chevelle for the first time in months after some work was done to it, Wilwood rotors and calipers all around, UMI performance front/rear Tubular control arms, front/rear sway bar, rebuild rear end set up for the QA1 Coil over front/rear,
Old 04-23-2013, 09:10 AM
dug dug is offline
Everything is looking really good. Do you have any more pictures of how you took the front cowl apart from the firewall? I'm re-doing my firewall on my chevelle and it looks like you had it at a point where you could have gotten a flat sheet and replaced the entire firewall if you had wanted too.
Doug
1970 chevelle, 383/turbocharged/carb'd/5 speed.
Old 04-23-2013, 12:20 PM
tubbed69's Avatar
tubbed69 tubbed69 is online now
looking good,you sure are moving fast
Old 04-23-2013, 12:27 PM
Che70velle's Avatar
Coming along nicely!!!
Thanks Dad!!
Old 04-24-2013, 07:24 AM
its already in the painting stage but I havent updated since last year
Old 04-24-2013, 07:25 AM
Thanks, its way way far along, its actually in the painting stage almost done, I will be adding more updates until I am caught up thanks a lot, good to see a fellow Chevelle guy
Old 04-24-2013, 08:27 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Even though you said that's not the final rendering, it's sweet. Gonna be a nice looking A-body. Keep the pics coming.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 05-02-2013, 01:44 PM
Default Updates
Well here I had finally taken the Chassis back to the body shop and at the same time I was getting the chassis ready, the underside was getting a nice threatment
Old 05-09-2013, 07:16 AM
Default 468 BBC Dyno tested at 586HP
While all the craziness of the car being worked on and chassis. I also was building a 468 BBC which was dyno tested at 586HP. I was hoping for a little over 600HP but do to the fact that I wanted to use pump gas and we were close to having to use race fuel which I did not want. We had to go with a smaller intake but at the end I was happy. I am not a fast driving guy so all this HP will probably never really be put to the test but it never hurts to have a little extra. Give me you imputs on it and my theme was to go all black since the entire engine bay will be red with a few satin black part such as master cylinder and so forth.
Old 05-09-2013, 10:51 AM
NOPANTS68 NOPANTS68 is offline
Looks awesome man. A BBC is a sight for sore eyes these days. I like your theme and attention to detail.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
