Old 10-05-2012, 08:38 PM
Sawzalls should only be used to remove old exhaust... and Fred Flintstone floors... because you can't cut ANYTHING straight with one!
Old 10-05-2012, 09:03 PM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by bdahlg68 View Post
Do the abrasive saws really cut cleanly? It's been a while since I used one, but I never remember straight cuts and I remember lots of cleanup after the cut.
Greg - I think you missed a few key tools. Sawzall, cut-off wheel, metal file, and teeth. Those are the ones I currently have!
I have a cheap Harbor Freight 14" abrasive cutoff saw.......a ten year old with a sawzall could produce similar results. The chassis flexes bad so even with light handle pressure it can't produce a square cut.
I imagine this Milwaukee might produce reasonably square cuts: http://www.milwaukeetool.com/tools/m...achine/6180-20
Old 10-05-2012, 09:15 PM
I have a DeWalt --- 14" --- it's about 200 bucks at Lowe's or Home Depot. Works great - I just don't use it much because it's slow and messy...
But then again -- I have a super spiffy Cold Cut Saw that is quiet - clean - fast - and makes perfect cuts.
Get ya one of these bad boys and you'll forever by a happy metal cutting man!
Old 10-05-2012, 09:26 PM
I should have posted this pic up -- which actually kinda shows the saw!
I mounted mine on "slides" because I have limited room in the "shed" - and have a wall to contend with - so I can move the saw back and forth on the slides to gain an extra couple of feet...
These use machining coolant... and that gets a little messy -- but the water evaporates and the oil is water soluble...
Old 10-05-2012, 09:44 PM
I hope you guys realize I'm just being funny here....
A decent quality abrasive saw will be a very versatile tool if used correctly... The Raptor style would be my choice if the guy can stand the noise and is willing to clean up afterwards... I think you have to be MUCH more careful with the Raptor style - they're higher speed - and the blades are mean and nasty. Fail to secure a part and it WILL fly across the room and imbed itself in a plywood wall! Ask me how I know that!
I totally get that most people don't have the space or $$ to be buying all this stuff.
Old 10-05-2012, 11:09 PM
Vince@Meanstreets's Avatar
I'd love to get a cold saw, my buddy scored one at a Goodguys swap meet for $300. The guy thought is was dead but it had a plugged pump screen and a loose switch connection...on top of that the guy didn't want to take it home. Win some loose some.
You aren't kidding about launching end cuts if you aren't carefull. A good center blade miter base would solve that. I like the Raptor blade, I cut very slow and let the blade do the work, the only think I do after a cut is deburr the edges. The dust from the abrasive chop saw gets to e, and it smells 3 hours after you had used it.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-06-2012, 10:07 AM
Another "plus" of the Cold Cut saw --- 50 RPMS.... no flinging parts... No heat in the part with the coolant/lubricant.... It just feels nice to use it. Sadly the cost and the power required are major impediments to home ownership.
A minor annoyance --- switching blades for different materials. They ain't cheap blades - and you need one for Al U mini Um --- and another for Stains Less Steel... and another for mild steel...
So around a "hot rod shop" where we're always cutting different stuff... it can be cumbersome.
Old 10-06-2012, 10:11 AM
Change blades even with the cold saw? Yeah I hear the blades are around $200.
Only takes a min to change mine. I think if I was a high output shop I'd just run 2 different saws with blades set. Like I have my die grinders. Haven't swapped a collet/disc support in years.
Dealer for
NEVER FORGET -11
Old 10-06-2012, 10:30 AM
It doesn't take but a minute or two to swap - but it's annoying. I want to take a piece to a machine - whack it - and move on.
Obviously for a commercial shop - having a couple saws isn't that big of a deal - but for the most part - on Lat G we're a bunch of home garage guys....
I've found that in my own situations -- a guy can't have too many ways to whack stuff -- and stick stuff together.... and bend stuff. It allows you to think in a different way. My thinking is never "how the heck am I going to build X" -- it's just "how do I want to build X"... without limits. That frees your mind up to just gettin' 'er done and makin' it kool.
Old 10-06-2012, 10:36 AM
badmatt's Avatar
badmatt badmatt is offline
I never have the change blades with the band saw for different materials.. teehee 6 tpi blade and let it eat.
