Old 10-26-2012, 09:12 PM
randy randy is offline
now on a ls2 gto swap into a car using 4.10 gears the close ratio would be the way to go also correct?
Old 10-26-2012, 10:22 PM
FETorino's Avatar
FETorino FETorino is offline
So chances are you are only running a 26" tire. Combine that with the low 2.97 first gear of a wide ratio and a 4.10 rear gear and your start line ratio would be way low and .50 final drive will make those 4.10s well 2.05. So you will have a first gear good for pulling trailers and a top gear for Boneville. Does that sound like what you want?
JMO close ratio is the only sensible T56.
A guy on another site made this spreadsheet to play around with ratios and their effect. Pretty cool, but I think some of the transmission ratios are wrong.
https://docs.google.com/spreadsheet/...SSExzU2c#gid=0
Rob in SoCal
Old 10-27-2012, 06:20 AM
DOOM's Avatar
DOOM DOOM is offline
[QUOTE=Flash68;443219]Close ratio vs wide ratio is the correct terminology. It's been around for 50 years. Todd's just had his head in the sand with that junk TKO.
Man you guys are brutal!!!Thanx again guys It's just getting old buying stuff twice!
Mario
USCOLLISION
Old 10-27-2012, 02:11 PM
lol wow that sums it up. i guess close ratio it is
Old 10-28-2012, 07:20 AM
intocarss's Avatar
That's the way I remember it
Old 11-25-2012, 05:26 PM
blazer1970 blazer1970 is offline
I'm running the 2.66 1st gear in my T56 Magnum with a 4.10 gear and 28" tire.
Works great at the strip and on the highway. Just my .02
Old 11-30-2012, 08:44 AM
gnx7's Avatar
gnx7 gnx7 is offline
The 2.66 1st gear version is what 99% of people are buying. You don't need a deeper 1st gear gear or you will simply blow the tires off and the nice thing is that 5th gear is .80 which is a closer ratio if you were to do some top speed accelleration "runs."
While the .50 overdrive is nice in the other unit.... i doubt any of us are building these for commuting and the end all be all in fuel economy.
I have the 2.66 1st gear version and 3.25 gears out back. Hoping for 750rwhp/750rwtq+ on e85. Holley EFI just announced their partnership with Davis Technologies (www.moretraction.com) for a traction control module. I won't be having traction issues when trying to ramp up the boost thru the gears. It is rather affordable too. ($599 base model or $999 for a self learning fully tuneable unit) Uses a driveshaft sensor to operate.
Old 11-30-2012, 08:51 AM
I prefer my right foot.
Old 11-30-2012, 10:49 AM
DOOM's Avatar
2.66 Is a done deal thanx to Todds expertise!! I got it all beefed up with all the goodies to handle a ''LITTLE'' more HP . Now all I have to do is get it American Powertrain has no Tremec cases ???? 6 weeks now.. Just called yesterday still nada!!!
Mario
USCOLLISION
Old 11-30-2012, 10:56 AM
Flash68's Avatar
Flash68 Flash68 is offline
Expertise? Based on what... his TKO experience?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
