Old 10-28-2012, 11:21 PM
randy randy is offline
Default When to start painting
I'm looking for feedback when you think it's time for paint when building a car from the ground up. Do you prefer.to install and disassemble every single piece of the car before painting or do you just wait to make sure all the outside metal work is finished?
Right now I'm just waiting to buy my engine and transmission so I can check for tunnel clearance. Would u then paint the car knowing you have yet to mock up an exhaust, brake system onto the firewall, seats, or even the vintage air bulkhead connector all parts that I still need to buy?
I'm trying to spread out the cost some so I'm buying in 5 phases that I still have left
Paint
ls2/t56,
brake system,
seats, vintage air,
Exhaust, misc parts
Old 10-29-2012, 12:46 AM
frankv11's Avatar
frankv11 frankv11 is offline
I would completely build car , prime it , drive it like you stole it. To get all the kinks and do overs. Once you are happy that everything works and looks well together blow it apart piece by piece and paint.
That's my plan. Nothing worst than cutting metal on a fresh paint job. Most often than not you will make changes before you get it to where you want it.
Good luck
Old 10-29-2012, 07:29 AM
cencalc6 cencalc6 is offline
Good luck
I Agree!!! Made that mistake once
Old 11-11-2012, 07:52 PM
well its currently jambed already. I just need some time to save up for a engine/transmission and a few other pieces. I have the money to actually finish it but i do not want to dip into my savings.
Since its jambed should i put the glass and everything in it or what? what would you do next?
Old 11-14-2012, 06:14 PM
snappytravis's Avatar
I wouldn't put glass in until it's painted, that way you don't have paint lines on all your weatherstrip, front and back rubber gaskets, (be careful)
Old 11-15-2012, 05:10 AM
69x22's Avatar
69x22 69x22 is offline
I would put it all together except for the wiring, and maybe exhaust. Once everything fits and the gaps are perfect blow it apart for paint. On the wiring make sure the hole for the fuse box is large enough for the new harness, some aftermarket harnesses require a larger hole. And don't forget the hole for your computer harness if you are running FI.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 10-29-2012, 12:47 AM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
In my experience I would prefer to completely build the vehicle, then disassemble and paint. It will all go back together quicker and smoother. Plus you dont worry about messing up the paint trying to figure things out that could have been solved before paint.
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 10-29-2012, 01:18 AM
Musclerodz's Avatar
Build it before you paint it.
Mike Redpath
Musclerodz & Customz
facebook page
