Old 12-29-2012, 10:03 PM
James OLC's Avatar
Default 2012 OLC Garage Sale
Updated prices and availability - February 1, 2013
Well it's that time of year again... Time for what has become the annual OLC Garage Sale...
I'll add a couple more parts over the next day or two as I get info loaded up...
Chase Cam System #1 - $500
PDR100 recorder
600 line bullet camera
Standard Camera mount
5' Mini DIN camera extension cable
Remote AA Battery pack
Chase Cam System #2 - $600
PDR100 recorder with G-force meter (auto start)
Suction cup mount mount
Standard camera mount
Cigarette lighter power adapter
PIM10 Power Isolation Module
Buy both systems and I'll through in a dual recorder mounting kit ($89) and a case.
McLeod RST Clutch #1 - $700
Part Number 6912-07
Includes Aluminum Flywheel
Part Number 560530
Approx 3800 miles, very good condition
Complete - drop it in and go (more pics available upon request)
McLeod RST Cutch #2 - $300
aka "Smokey"
Part Number 6912-07
Part Number 560530
Needs clutch disks (available below)
Needs floater plate (it's badly warped)
Selling for less than cost of the flywheel - piece it together and go (more pics available upon request)
McLeod RST replacement clutch disks (front and rear disks) - $240 (pair)
Front disk PN 6919-07
Rear disk PN 6920-97
Anvil carbon fiber hood - $1200
PN 010043: Satin 67-69 100% Carbon Fiber Bare Hood
Used - body worked and painted by Best of Show
Includes 1 vent with screen - needs 1 vent with screen
Set up for hood pins but can use stock latch as well
Anvil carbon fiber rear spoiler - $250
67/68 Satin Carbon Fiber and Fiberglass Rear Spoiler
New - newer used, never mounted
Anvil carbon fiber header panel - $200
PN 010038: Satin 67-69 Carbon Fiber/Fiberglass Header Panel
New - never used, never mounted
Anvil carbon fiber cowl panel - not available
PN 010041: Satin 67-69 Vent Delete Cowl Panel with Recess
Michelin Pilot Super Sport tires 2 x 325/30ZR19 - $775 (pair)
New - never mounted - perfect condition
Marked for 2012OLOA
Michelin Pilot Super Sport tires 2 x 275/35ZR18 - SOLD!
Marked for 2012OLOA
Michelin Pilot Super Sport tires 1 x 325/30ZR19 - $390
New - never mounted - perfect condition (located in IL)
Marked for 2012OLOA
Michelin Pilot Super Sport tires 1 x 275/35ZR18 - $225
Marked for 2012OLOA
Kinsler Spec Bosch 10211 Fuel Pump – new in the box (was an OLOA spare) – Retail was $360, asking $300 obo plus shipping.
Track Rat Engine - All aluminum 5.3L LS with Trick Flow heads. Made 445 ft.lbs. and 491 HP. You can see all the information on the build in the July '09 issue of Camaro Performers. Comes with harness and ECM - ready to run. Great engine in perfect condition but I have a line on a better suited engine for the wife's car if I can see this one.
Includes accessory drive - Concept One "Victory Series" accessory drive - black anodized with Sanden (Vintage Air) AC, powermaster alternator, and integral PS reservoir. Again all the information on the drive setup is in the June '10 Camaro Performers
Looking for $8500 complete. Will not seperate but I can remove the accessory drive if the buyer of the engine does not want it. Pickup in Escondido, California or I can arrange shipping at the buyers expense.
Engine (headers and engine stand are not included in the price):
Accessory Drive:
... everything is first PM or Email, first served.
Parts are in Central California (unless otherwise indicated) so delivery within California might be possible depending on timing and location.
Thanks for looking!
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 12-30-2012, 12:25 AM
Flash68's Avatar
Flash68 Flash68 is offline
You know I like scraps James... what else ya got?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 12-30-2012, 04:41 AM
robin93784 robin93784 is offline
Default Cowl Panel
ANY CHANCE TO SEND ME A PIC OF THE COWL PANEL [email protected] THANKS
Old 12-30-2012, 08:42 AM
KPC67's Avatar
KPC67 KPC67 is offline
Pm sent on clutch #1
Kevin Carter
Old 12-30-2012, 10:04 AM
James OLC's Avatar
I don't know if I have that much hard core stuff left Dave but there are some more bits and pieces coming...
You can see some of the cowl in the pic above but I will try to get you a picture of the cowl off the car after New Years.
No guarantees on getting it to Calgary but if you decide it what you need let me know and I'll see what I can do
Originally Posted by redsand View Post
do you have any pictures of those
Picture added - I'm sure I can find some more
James
1969 Camaro - Dusty
Old 12-31-2012, 01:00 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
I should probably buy those 275 tires from you. If I buy all three will you give me wholesale pricing? I can almost guarantee I will have to "resell" them to Gregg and Steve.
