Old 08-25-2013, 09:01 PM
Operations's Avatar
Operations Operations is offline
Default ZR1 Brakes
Originally Posted by will69camaro View Post
So I REALLY want to run new ZL1 brakes on my 69 camaro build. I have the DSE subframe and the DSE 9inch rear. I am told the V brakes will bolt onto the subframe (same as ZL1), however I'm curious about the rotor to use. Maybe verification on that also if I have been told incorrect information about the caliper fitting the subframe.
I know for the rear I need a bracket made to run the caliper, that shouldn't be that hard. There is someone working on one on Pro-touring that I have seen linked on here.
Does anyone have experience with V/ZL1 brakes on a detroit speed frame? I just want to see if there is information out there before I buy a set of calipers and measure for the rotor.
Car will be done with the chassis work soon, and then it's off to paint. I'm hoping to get brakes and wheels/tires for the car for when it returns from paint. They're "next" on my list of modifications to the car.
Thanks for the help guys!
William
Did you get this figured out?
