Old 02-25-2013, 09:29 AM
canrc canrc is offline
I used the summit brand fittings but used Russell black nylon hose and have had no problems with either of them.
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 02-25-2013, 10:13 AM
bentfab's Avatar
bentfab bentfab is offline
Chad,
I think the hole industry went thru a bad batch of hose a couple years back. If I'm not mistaken there's only two manufactures that supply to EVERYONE and then they private label it. I had a few issues of my own on a couple projects back then. It dose not matter if its black or s.s. braid. It all has the same inner lining.
This is one of the major reasons why I try to do as much hard line as possible for any system on a car.
Mark
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 02-25-2013, 10:18 AM
strtcar strtcar is offline
I've got Earl's black braided hose on my TA. One of the first things I intend to do with the car when I start working on it again is replace all of it with hard lines and PTFE hose. The smell is terrible.
I agree, I will only use hardline if I ever redo my flex lines, the smell sucks.
Old 02-25-2013, 10:40 AM
realcoray realcoray is offline
Originally Posted by EBMC View Post
Although a lot of summit brand parts work well, including their fittings, their hose is not one of them! We bought some a few years back to try on one of my personal cars and wound up throwing it all away. We have been using hardline andTeflon hose on most everything and for sure on any FI systems.
I think it's more like if you run fuel through non teflon braided hose, it will eventually fail like this, not so much in whos hose you're using.
Summit does not manufacturer the things they sell under their name, and there is a reasonable chance what they sell is just rebranded Earls (or some other mfg they sell).
chr2002ca's Avatar
Just in case you were thinking about PTFE lines as an option, I just did an EFI fuel system install on my car and used both the Aeroquip S-TW PTFE hose and SuperGem fittings and the Earl's Speed-flex lined(static dissipating) PTFE hose and PTFE fittings. The Aeroquip SuperGem PTFE fittings are less expensive(aeroquip.cc) and easier to install, but the Earl's hose is less expensive even though it has the inner lining for eliminating static build up. Overall, the same price for both hose and fittings with Aeroquip being a little easier to install the fittings on the hose. Neither of these companies offer a black PTFE hose though. I know Pegasus does, but it's $$$. I think another company does also, can't remember the name.
Chris Robinson
Old 02-25-2013, 10:44 AM
DRJDVM's '69's Avatar
Ive used the Earls black hose and havent had any issues but have heard of some that have.
I plan on going over it with a "microscope" when I get the car back on the road this spring....I may change it out even if it visually looks ok on the outside..piece of mind
I just bought the 911 PTFE hose from Pegasus Racing for the Cuda...its nice but its frickin expensive. About 3x as much per foot. Im going to run alot of hardline but even just the short sections from frame to tank etc cost a pretty penny.
Old 02-25-2013, 10:59 AM
intocarss's Avatar
http://www.anfittingsdirect.com/part...854f4f508671d3
Old 02-25-2013, 11:04 AM
Flash68's Avatar
Flash68 Flash68 is offline
Why is that so dang cheap? Any experience with it?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 02-25-2013, 11:06 AM
EBMC's Avatar
EBMC EBMC is offline
True, it will eventually fail and fumes will come through no matter what, But the Summit hose we had did not resemble any "name brand" hose that we were familiar with. I have no idea who makes (made) it for them. But, This was also a few years back and it may be different now.
Steve Keefer
Old 02-25-2013, 11:08 AM
intocarss's Avatar
I don't have any personal experience. I do know a couple of shops that buy from them and were happy
