Old 04-14-2013, 05:20 PM
I love it!!
Old 04-14-2013, 05:48 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
that really is a cool car,sure should pop in the sun,body and paint look slick and straight,good job
Old 04-14-2013, 06:26 PM
rjsjea's Avatar
rjsjea rjsjea is offline
who's product line is the "liquid metal?"
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 04-14-2013, 06:32 PM
elitecustombody's Avatar
Have you had a chance to take it outside to check for blotches under natural daylight?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 04-14-2013, 07:43 PM
Iamtheonlyreal1 Iamtheonlyreal1 is offline
Banned
We got the chance to open the doors afterwards, and all looks good, but not outside yet.. We also practiced painting on old fenders and doors, so we can gather the necessary amount of coats, along with used a few different spray patterns during the process on each coat, so we could be sure that all the various contours were hit at as many directions as possible.. Between coats, we would also walk around the car looking at about every angle we could, and would look at it with different lighting..
Once you hit the correct number of coats, the blotching really disappears.. All the way till about the 4th or 5th coat, there was some blotchiness, but once you hit the 5th and into the 6th, it really just disappears and becomes a uniform color.
Old 04-14-2013, 08:03 PM
pw2006's Avatar
pw2006 pw2006 is offline
That looks very cool!
Rob
69 Camaro PT project- LS3/4L70e, Budnik's, Ridetech, Speedtech, Wilwood, DSE tubs, 4 link, shortened Moser 12 bolt- in progress
Old 04-16-2013, 01:26 PM
Banned
I open the doors of the shop, and I tried to catch the color changes the best I could, and I was caught a bit off guard. As you can see, with natural sunlight, I have alot of graphite color in it, with major flat areas in the bright silver/metal color, depending on where you are standing.. Artifical lighting does not have this affect, and it wasnt really as noticable with the smaller test parts, but it is pretty dramatic as a complete paint job. We have complete coverage with the liquid metal, and you can see complete coverage in the dramatic darker color shift areas at close up inspection, eventhough it appears to be somewhat blotchy in the pics.. This color does some strange things, and I am even assuming that the Wet Sanding and Buffing is going to make even more difference, due to the potential affect of Direct Lighting that basic Orange Peel of the Clear Coat, because this color is very sensitive to direct or indirect light and angles of light.
We plan on getting the car outside tomorrow, because the jambing should be completed later tonight, so we can get it back together tomorrow. More than likely wetsanding and buffing will also start tomorrow, so I will be able to see if there are any changes after that is completed.
(With the Door Open)
(Before the Open Door)
(Door Open, but from different views of the rear quarter, so you can see some of the transition)
Old 04-16-2013, 05:26 PM
It looks SWEET Robert. Nice work.
Old 04-19-2013, 07:45 PM
Banned
Here are some pictures of the underhood and jambing process, some of which we had to redo again, do to some sort of odd clear coat reaction. We are using the Suggested PPG clear coat for the PPG Vibrance paint line, which is a pretty fast drying clear, but had no idea it was necessary to recoat within 5 minutes, or it would eat itself? I dont know how we didnt get the reactions with the overall paint, because we waited way longer between each coat, so I guess there is a before and after window for coats.. Called the PPG rep, and they just said that is the way it is, and they cant believe that we are painting the whole car with this color and process.. LOL My painter is a DuPont guy, so he wants to wetsand the PPG Clear already applied to the exterior, and then apply an overcoart of the DuPont Clear system that he likes to use, because he said it is a much better system, and would rather work with it on the exterior for buffing and finish work. We sprayed some DuPont Clear over the wetsanded PPG clear on some previous test panels, and all looks good, so we are going to go this direction.
The Trans Tunnel and Center Underside of the Hood will have an Insulation/Covering on it, so all you will actually see it the hood bracing in the Liquid Metal color. The Center Underside of the Trunk will have an upholstered insulation panel, so they may not appear to be finished as well as the rest of the area's.
Liquid Metal without Clear
Final Clear Coat
Old 04-19-2013, 08:35 PM
Steve1968LS2's Avatar
Very cool.. and that is a HARD effect to capture on "film"...
Super nice, and very unique!
