Old 06-21-2013, 02:42 PM
strtcar strtcar is offline
looking good.
Old 06-22-2013, 06:29 AM
Nice car. I really like the purple color.
Old 06-22-2013, 10:21 AM
Ed.Capen's Avatar
Ed.Capen Ed.Capen is offline
Good Guys
Looking good Jeff, as you know I like these Buick's.
See you at Columbus.
Goodguy Ed
[SIGPIC][/SIGPIC]
Old 06-25-2013, 07:57 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
The underside of the body has been prepped and undercoated
Ready for chassis transplant
Chassis mounted, along with the LS3 and 4L65E!
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 06-25-2013, 08:03 AM
Racerdave24 Racerdave24 is offline
Default Nice!
That was already a sharp looking car.
When you guys are through, it will be an amazing car. I'll be watching this one.
Old 06-26-2013, 05:51 AM
Evan Iroc-Z Evan Iroc-Z is offline
Where can I get a set of those wheels made? I know the trend in certain communities has been the wagon wheel look, but you guys took that to a whole new level!
Looks fantastic! Keep up the good work.
Old 06-26-2013, 06:00 AM
Rick D's Avatar
Rick D Rick D is offline
Nice job guys, I like that it will look mostly stock but still kick ass on the road and track!!
Rick
Old 06-26-2013, 02:52 PM
Supporting Vendor
This car was originally a column-shift automatic with a bench, and eventually switched to a floor-mount shifter with a console. So we cut the stub off of the column, filled & painted the area.
The column on these have a 1" 48-spline shaft
When the stock column is used on our chassis, with an LS engine & our stainless headers, 3 joints are needed in the steering shaft. An aftermarket (Flaming River/IDIDIT) column that is a little shorter can typically use a 2-joint shaft. To support the shaft, we used a 3/4" heim joint on a custom bar mount. To keep it from pivoting around the tube, a hole was drilled & tapped into the tubing & bolt inserted.
Black anodized billet serpentine system installed: w/Sanden AC compressor, 140a alternator, power steering, ATI dampener.
SchwartzPerformance
GMachineChassis.com
LSxEngines.com
Old 07-03-2013, 12:08 PM
Supporting Vendor
We mounted the Vintage Air Gen IV system underneath the dash with easy custom brackets, and fabbed hoses to the firewall bulkhead fitting.
Vintage Air's kits often include too many items that we end up not using, so our preference is to do most of it our own way. It often ends up being cheaper, too.
New 18x9" Forgeline's and 255/40/18 Pirelli tires
18x11" Forgeline's and 295/35/18 Pirelli's fit nice in the stock tubs
The customer picked up some used Cadillac seats which integrate the seat belt/retractor into the seat rather than the pillar, or using a roll bar and harnesses. They're a little taller overall than the stock seats, but the seat bottom height isn't much different, so it doesn't feel like you're driving in a truck!
SchwartzPerformance
GMachineChassis.com
LSxEngines.com
Old 07-30-2013, 03:55 PM
Supporting Vendor
Installed a Baumann trans controller under the console and cut a hole for the digital readout & adjustment knob in the bottom of the console box.
Front end fitting!
The new C&R radiator being fitted for installation. This radiator was designed for a Chevelle / A-body, but does not bolt-in to a Skylark.
To fit the radiator with the factory mount, we had to modify! Part of it was cut and re-welded, and the mounting bosses on top of the radiator were utilized by drilling holes in the newly fabbed piece.
There was an air gap in between the rad & core support, we filled the gaps on either side by bending a couple of sheet metal pieces.
Determining placement of the ABS module
SchwartzPerformance
GMachineChassis.com
LSxEngines.com
