Old 05-23-2016, 10:08 PM
MtotheIKEo MtotheIKEo is offline
I made mine 16" long x 14" wide. I also made them so each corner is actually 2 cribs stacked since my jack wouldn't lift my car high enough in one shot.
As far as strength goes, we used to stack 20k lb roof sections on 36" high cribs (one at each corner) built the same way.
Old 05-25-2016, 11:57 AM
Zoomin Zoomin is offline
Glad you asked the question as I need to build a set myself. I have a two post lift, but there's some things that require having the weight on the suspension.
1964 Lemans
1966 Skylark
1969 Camaro
Old 05-25-2016, 12:44 PM
SSLance's Avatar
SSLance SSLance is offline
I made the tops of mine flat all the way across and I put shims under them so that they sit perfectly level on my unlevel garage floor. This gives me a flat platform to use when making suspension adjustments with the weight on the tires. Being flat on top lets me use turn tables to check and set caster while on the blocks.
Lance
Old 05-25-2016, 03:44 PM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Car Blocks
Lance I was under the Firebird many moons ago
with it sitting on jackstands when we had a 5.0 quake
I was out from under that car in no time
It does make you think about it
My new shop has t-bar ceilings with 2x4 drop-in
lights.. I don't think the lights have the extra wires
and there are no compression posts on the ceiling grid
that we normally do on new ceilings...(I am a contractor)
The building is metal and will flex but I am sure lights and ceiling may not
be good bouncing off the cars
Bob
Old 06-01-2016, 08:20 AM
minendrews68 minendrews68 is offline
I made mine 16"x16", 6" tall. I also made them where I could interlock them together and get additional heights at 6" each. Best money I've ever spent. Although, (and it takes a little work) find where someone is building a house and ask if you can go through their scrap 2x4's. I'm betting you could probably get enough free wood to build them.
Old 06-01-2016, 02:46 PM
G-Body's Avatar
G-Body G-Body is offline
Best tool in my garage is these blocks never a worry to climb under car and u can have car at ride height wit out suspension hanging!
have had mine for 10 yrs.
Old 06-01-2016, 04:50 PM
Yea I built mine 16" x 16" as well as you can cut clean 8ft 2x4's into this length and have no small scraps. I made mine 8 stacked high so they're right at the top of my jack which is nice. Feel 100% confident crawling under the car, which I never was on jack stands.
Wish I had built them sooner. Cost about $35-40 in materials.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 06-01-2016, 07:26 PM
randy randy is offline
I did the same but made another set 5 stacks high. I use the short ones to get the car up under all 4 and then the 8 stack so that they are 12 stacks high. Easy to work on
