Old 06-24-2013, 05:39 PM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
Default New car/Project! 67 Firebird
Almost a Camaro! Now I will see if this first gen stuff really is so cool everybody thinks! This is the most expensive car I have ever bought, always have had somewhat "cheaper" cars, but hey, you only live once! And this is my first car on a forum.
It is a 1967 Firebird, it has a lot of Nice parts, but still needs a lot of work, because it is basically a bit "shoddy" put together...
I dont know everything yet, just got it. Have a list but I must check it out myself to be sure.......
But in short it is supposed to be:
461cid Pontiac -stroked 400, Wenzler heads and roller cam. Put together by a Company, not selfbuilt, and dynoed.
TKO600 gearbox, Coleman driveshaft, Strange 12 bolt, 35 splines. Leaf springs.
Sweet short steering box. Heidts front A-arms and coil overs, small willwood brakes on all 4, 15" Wheels fits. And some other stuff, but this is the main stuff.
The clutch pedal is so hard that you must be a "strongman" to push it Down(and I do lift weights too....) Im gonna check how the pedal ratio is tomorrow, I think the hydraulic pump rod is just mounted wrong, hope so atleast..
And it seems to be Stock ball joints, so seems to be Stock front end geometry, so the tubular arms just looks good and dont do much good.. It even seems to be shimmed for LESS caster..
It is like this the whole way through the car, some homemade brackets for servo and alternator that dont align properly and throws belts and such, even though it is a lot of good and expensive parts it is basically put together sloppy and fast in many ways, most of this seems to be "free" repairs that will make this car a really fun car!
