Old 10-20-2013, 06:40 AM
Jon69RagTop Jon69RagTop is offline
Default Zero regrets on this purchase, around $3,000
https://system.netsuite.com/core/med...ry=US&gc=clear
Quality Lifts
Old 10-20-2013, 06:52 AM
dhutton dhutton is online now
http://www.directlift.com/Default.aspx
There will probably be some show special pricing at SEMA.
I have a four post and a two post from Direct. Will be getting a second four post this week. Great way to free up floor space in my shop. Much less than the estimate I got to put on an addition.
Don
Old 10-20-2013, 06:55 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I've had a BendPak for several years. Bought from an Ebay vendor who also carried the Danmar. I don't remember exactly what I paid. Did the install myself (by myself using a hoist). Mine is the 10,000lb with the canted posts and operates on 220/240. Was easy to setup/install and has worked flawlessly.
Jeff-
Old 10-20-2013, 07:59 AM
Orng Crsh Orng Crsh is offline
I have had a Directlift for approx. 5 yrs. with no problems. The price was better than most others and when I saw that SW (Streetking) used Direct in his personal garage for his expensive toys, I was convinced that was the way to go.
Old 10-20-2013, 09:05 AM
Richio1's Avatar
Richio1 Richio1 is offline
Another thing to consider is the cost of the accessories. My dad got a 4 post a couple years ago at Hot August Nights. Got a great deal on the display unit. Negotiated in 4 plastic slider trays and 2 metal slider trays. These are the trays that fit inbetween the two ramps.
In his research he found that the cost for these items vary quite a bit. Other things like bottle jacks, oil drain stands, tranny jacks, ect are sold by many of the vendors that you may want to try to negotiate into a package price.
Jeff
Lateral-g Feature - https://lateral-g.net/forums/showthread.php4?t=44186
Build thread - https://lateral-g.net/forums/show...ght=brownstone
Special thanks to Matt's Classic Bowties along with
Old 10-20-2013, 03:23 PM
69x22's Avatar
69x22 69x22 is offline
Thanks for all the info guys. I will defiantly be researching the lifts you guys mentioned.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 10-21-2013, 05:05 AM
TomM's Avatar
TomM TomM is offline
Check this one out. I bought it, works great....
Greg Smith Equipmemnt...
http://www.gregsmithequipment.com/At...rage-Pro-8-000
T,
Old 10-21-2013, 05:47 AM
SSLance's Avatar
SSLance SSLance is offline
I bought an Atlas 2 post lift from Greg Smith Equipment and can vouch for it's quality and the company's support. I would buy an Atlas and from GSE again if needed.
Lance
Old 10-21-2013, 08:43 AM
onevoice onevoice is offline
I have a BendPak. A 4post isn't the greatest for working if you need to remove tires, but I love mine for other service and storage use. Mine is a high and wide version, and I have no problem parking a full-size lifted PU on 35" tires under it.
If you want to park a full size truck under it, make sure it is wide enough to get between the posts without folding the mirrors.
Old 10-21-2013, 09:18 AM
Dieselman Dieselman is offline
I have a forward 12,000 lb that I purchased used. It's an older left but t works great and is very sturdy.
While researching lifts several years ago.There was a guy on one of the forums that suggested to all not to get any lift that is not certified. I don't recall the particulars. However, I remember there were horror stories.
Good luck with whichever brand you get.
