Old 10-21-2013, 11:38 AM
Sieg's Avatar
Sieg Sieg is offline
Good points GW
I've found 65-75% balance and 180-200hz works for me on the 6061/6063 I've been playing with. Though 100hz is a lot nicer on the ears!
Old 10-21-2013, 12:28 PM
Revved's Avatar
Revved Revved is offline
If you haven't already there is HUGE information covering just about everything TIG in "TIG 101" and "TIG 102" threads in the Shop & Equipment sections here. They seem to be an ever growing wealth of information with great tips from the guys on the forum that really know their stuff and lots of "what not to do" from the rest of us!
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
Old 10-21-2013, 07:13 PM
E.rodz's Avatar
E.rodz E.rodz is offline
looks like you are making great progress! it is a very tricky metal to weld so when you do master it everything else will be easy some tips I can contribute is aluminum is very finicky to weld especially when welding thick to thin there are some tips to help you with this. first clean alum with a CLEAN STAINLESS BRUSH USED FOR NOTHING ELSE! wipe your filler rods too and do not let them lay around the welding bench to get contaminated with grinding debris. Take G.W.'S advice on balance . I often use a propane torch to pre heat the thicker alum. with a torch to get the molecules moving,keep most of your heat on the thicker piece the heat will automatically wick to the thinner piece.something like one second on your thicker piece 1/2 second on the thinner piece.you will come along in know time you are doing a great job already just keep practicing and you will be laying them down like a pro!
my name is Eric Hokenson I have a dream of building ten of the coolest hot rods out of my home shop wish me luck I am going to need it! - more pics on my web site www.erodzcustoms.com this is just for fun and i am NOT looking for any more work!
Thank you supporting sponsors! without you guys there is no way I could do this myself !
Modern automotive performance,Ring bros.,Yank convertors,extreme drive systems,Cj tunes,race coatings stainless works,Modern Automotive Performance.all of these shops have the experience to get your car to the top.
Old 10-22-2013, 09:17 AM
Scubachef Scubachef is offline
Thanks GregWeld for the answer/explanation. I definitely learned something that will be helpful moving on. I will have to check the material used for the legs to see if it is weldable.
Sieg- the day I can weld like those pics....I fear is never coming
Thanks again everyone for the responses. I read through the TIG 101/102 posts and definitely was taking notes there too!
I will posts a picture of the brake when I'm triumphant!
Old 10-23-2013, 11:28 AM
So I'm back in business. I switched to a #8 cup and adjusted balance and no more tungsten issues.
I still had some issue with joining the two metals of such different thickness, but that's just my lack of skill.
Here is where I'm at, it is not pretty but functional I think. Lots more practice needed but at least it is a step in the right direction.
Thanks again for the help guys.
Old 10-23-2013, 12:02 PM
Always tack the ends first. Then if you want to run a bead you can start "back" and run it to the tack. That keeps you from blowing out the ends when there's nowhere for the heat to go.
With aluminum it's very important to "finish" the weld with an extra dab of fill and back out of the throttle so as not to create a crater which WILL crack.
Glad to see you got it.
Old 10-23-2013, 01:22 PM
Sieg's Avatar
Big improvement!
Old 10-28-2013, 10:54 AM
Here is a video I thought really explained AC balance well. Balance was definitely my problem I was having and after seeing the video I really understand it better so I thought I would share.
Old 11-14-2013, 01:53 PM
64pontiac 64pontiac is offline
I find myself always going back to a green tungsten for aluminum. I seem to get way better beads with it. Also found that you won't want to sharpen the electrode to a point for a/c, it needs to get a nice ball on end. Heat is critical when you are struggling with aluminum, you need to be hearing the bacon sound! If your having a hard time adding filler, you need heat. Play around with torch angle too.
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 11-14-2013, 09:44 PM
Green balled tungsten is for old school NON inverter machines. Modern inverter machines need the proper pointed tungsten.
