Old 11-21-2013, 09:06 PM
jovozx12's Avatar
jovozx12 jovozx12 is offline
Does welding up the stock frame make it comparable to an aftermarket frame? I'm guessing not. Does anyone know how much of a difference this makes.
Old 01-18-2015, 03:16 PM
rallystyle rallystyle is offline
figured i would bump this up instead of starting a new one.
what is the preferred method for welding. i only have a tig and was thinking that should be fine? and er70s-2 filler ok?
1970 El camino
1969 camaro
1996 civic
Old 01-18-2015, 03:24 PM
Vince@Meanstreets's Avatar
Personal preference.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-18-2015, 05:05 PM
Rod P's Avatar
Rod P Rod P is offline
welding it makes it dramatically more stable...with good control arms, steering box and arms and it is very good, you can run a 10 inch wide rim with the stock frame, on some aftermarket frames you can run 11-12 inch wide rims
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 01-18-2015, 05:39 PM
Once you get in you will see how inadequate the factory welds are. TIG should be fine but after it's been baked and media blasted. 70 is good
Dealer for
NEVER FORGET -11
