Old 05-31-2015, 10:00 PM
Grimmey71 Grimmey71 is offline
Similar problems here, the guys at tremec told me to give it 1500 to break in, I just hit about 1800 miles and the shifting is improving though. Also I'm considering the white lightening shifter too
Old 06-02-2015, 12:35 PM
samckitt's Avatar
samckitt samckitt is offline
Dale brings up two good points. Clutch air gap can be a factor.
So how do you gain more clearance in the clutch if its not disengaging enough?
Scot
86 Monte SS
LS2/T56 Magnum
Old 06-10-2015, 05:02 PM
GMJim@HDC GMJim@HDC is offline
The Magnum will usually have a little crunch when cold up shifting into third. This is normal and usually goes away after a short warm up. One of the Tremec engineers refers to as the third gear nibble.
Old 06-11-2015, 08:38 AM
JodysTransmissions's Avatar
JodysTransmissions JodysTransmissions is offline
Guys with notchy T56 shifting; did you remove the T56 front plate and do a bellhousing alignment procedure referencing off of the input shaft bearing bore?
Jody Haag
Jody's Transmissions on Facebook
Old 06-18-2015, 07:40 PM
Terminator1 Terminator1 is offline
Default Crunchy 2nd-3rd T56 Magnum Gear Shift
I have not aligned my bell housing, where can I get a procedure for this?
Old 06-19-2015, 04:28 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Yes! BTW, I have about 2000 miles on the transmission now and the 3rd gear nibble is dramatically improved and seems to be getting better all the time. It is virtually gone once the gear box gets heat soaked.
Here is a how to:
http://www.pro-touring.com/threads/1...ousing-dial-in
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 06-28-2015, 05:48 PM
Thanks Guys,
Installed a quick release clutch quadrant, seems a little better.
Based on what Steve is seeing, I will give it a little more time before pulling the transmission to check the bell housing alignment.
