Old 12-15-2013, 07:03 PM
NOPANTS68 NOPANTS68 is offline
I've done a couple LS engines with carbs and have had great results. It's super simple and the MSD controller is easier to use than a phone. As far as the fuel changes, hard starting, etc. etc.- I don't know about all of that. In fact, my results say otherwise. My 3200 lb. Nova ran mid 11s all day, any day with a T56 and 3.73s with a used LS1, cam, a 750HP, and hand ported 853s. No big deal, plus it looked awesome and different. I think I'm pretty good with a carb, so it's my preference. Go with what you know, but at the end of the day you can't convince me the EFI looks better than a Victor and a carb. BTW, in most cases LS engines make substantially more peak power than the plastic EFI setups.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 12-15-2013, 11:46 PM
Rod P's Avatar
Rod P Rod P is offline
dude if you want it carbed then do it, when I popped the motor on my car, a carb LS made sense, already had a kick azz fuel system and a great carb, so I swapped in the LS dropped on an edelbrock intake and the MSD 6010 box (3 wires to hook up!, power, ground, tach) and I drive my car everywhere with the same fuel system(holley HP Billet 12-890), transmission(t-rex 4 speed), drive-line(8.5-10 bolt with detroit tru-track), everything I had before but now I get 19 miles to the gallon and still kick butt on the track
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 12-16-2013, 01:31 AM
Vince@Meanstreets's Avatar
EFI is the ONLY way to go --- for all around performance and drivability….. but it IS expensive to convert… so I get it when people just want to stick with a simple carb and distributor they have. But if you can swing it - EFI all the way.
The way I see it, if you gonna do an LS and have the intake go all the way with it. A PCM program, Walbro pump and a C5 regulator to me is cheaper than a carb ,fuel pump and ignition controller. If your getting a long block with no PCM, Harness or intake then yeah, its the easy route.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-16-2013, 03:17 AM
LS1-IROC's Avatar
LS1-IROC LS1-IROC is offline
I just don't get the argument for cost when talking carb or EFI. If you shop smart and have some wiring skills you can do EFI for cheap.
Old 12-16-2013, 06:22 AM
I agree with you -- but you're also making some big assumptions. Most people are fine "mechanically" but when it comes to wiring -- they're nightmares.
So yes - it can be done inexpensively IF you know what you want - and how to put all the parts and pieces together to make the system work. That's usually not the first time guy.
