01-10-2014, 06:24 PM
Thttp://ls1tech.com/forums/conversions-hybrids/1666379-warning-redesigned-russell-fittings.html
And then I find this thread, about the new style U-Clip screw style fitting failing.
So it turns out that both can fail, I guess?
My plastic clip fitting is supposedly a new design over the original plastic clip fitting. Since everything made by man has the possibility of failing, what do you do?
01-10-2014, 06:59 PM
After reading that thread, I'm going to just use the U style and loctite it. I think it probably just vibrated loose over time and loctite should prevent that.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
01-10-2014, 08:38 PM
Yeah, that's what I'm thinking right now.
My wife is a mustang person. She's had 3 really nice ones, and as I recall, changing her fuel filter on one of those cars, the filter was held on with plastic clips. It was aggravating, and seemed cheesy, but it worked.
But I refuse to spend good money on my car, only to have it burn to the ground because of a $10.00 part.
01-10-2014, 11:22 PM
One of the parts that failed I believe was not a Russell design but I cannot for-sure confirm. Either way, the U-nut is far better but one must always practice proper tightening of any nut. Suspension, engine, etc., they all must be properly tightened.
There's also these from Earl's. The retaining clip is likely the same as those used on the current LS3 based fuel system (it looks almost identical.)
http://www.holley.com/assets/images/ProductFlyers/Earl'sQuickConnect.pdf
01-10-2014, 11:32 PM
Carl, I have the plastic clip style fittings, made by Russell. I was told that the previous design fitting was known to be faulty, but that since then, there has been a revision, and the new design is "faultless". I just purchased these. What do you know about a revision to these fittings? I have no problem throwing these in the trash, and purchasing the U-Nut style if I have something faulty. Thanks for the heads up!
Sorry, I don't know if there was any change. As far as faultless, that's a pretty hard claim to make.
01-11-2014, 12:47 AM
Could someone pro like CarlC create oem style fuelline kit with nylon hoses and easy to adapt fittings? I am bit tired of heavy steelbraided hoses and all an adapters.
63 Z06
01-11-2014, 06:29 AM
You can go with the kevlar braided hose Pegasus sells. I'm using their regular braided hose on my Jeep, but I am going braided front to rear (PTFE lined, so no chance of smell or seepage).
www.pegasusautoracing.com/productselection.asp?Product=3490
01-14-2014, 08:32 AM
Originally Posted by OBeer-WAN-Kenobi
Originally Posted by CarlC
You absolutely, positively, do not want the fittings used in the Speedway kit. The plastic clip type, when used in an aftermarket aluminum housing, has shown more than once to come off while the fuel system is pressurized and running.
See here.
https://lateral-g.net/forums/show...burning+ground
I'm pretty sure mine came with the kind that are on the right in the picture in your thread. If you look at the second picture on the speedway link it shows that type. I believe that's what I have, but I'll check.
I have confirmed that my kit did in fact contain the "U" type so I'm good to go. Speedway should probably change their image so they don't lose sales due to people thinking they have the other type of fitting.
'69 RS Camaro
12-01-2014, 04:23 AM
can I get those fittings for -8 lines vice -6 or do I need an adaptor? Thanks
12-01-2014, 03:54 PM
The U-nut design is available from Russell in AN8 sizes. I don't have the part number with me, but the AN6 is 644120. Search the Russell website and it should get you close.
